Monitor no longer will switch to Analog (VGA) source.
...This suddenly happened to me when I tried to play my XBOX 360, which uses VGA. Whenever I try pushing to "Source" button, it keeps switching back to Digital (DVI). The only way I can get to VGA mode is if there is a signal in DVI mode, which means I have to turn on my computer every time I want to play my 360.
Why is this all of a happening all of a sudden? I tried using the "Factory Reset" feature in the menu, and have even unplugged the power cable for at least 6 hours, to no avail.
  • 4 more comments
  • rogue1234 Mar 08, 2008
    I have just the opposite problem. It will only take an analog signal and will not recognize digital. Checked cables, tried menu to change input options from analog to digital but it just keeps saying no analog signal if I am hooked up to dvi.
  • Psythik Mar 14, 2008
    I tried a 24-pin Dual Link cable, but I still can't switch to VGA unless my computer is on (which uses DVI, as stated before). I don't understand why I was able to switch back and forth between sources without a problem just two weeks ago, and now I suddenly can't. I think I might have to send in my monitor for warranty service (assuming it even has a warranty...).
  • Anonymous Sep 07, 2008
    I have exacty the same on a LG flatron plasma, i connect my decoder to the composite (av) and my pc to the vga, but with no pc powered then i am stuck in vga mode, if i switch the pc on(signal in vga ) then it lets me change to av....all begun whn i tried to run a Nitendo wii in rgb mode
  • ccmdphd Dec 27, 2008
    my syncmaster is stuck in tv mode, not dvi. nothing I seem to do will bring it out.
  • Anonymous Mar 19, 2014
    i am trying to use a hdmi cord to play my xbox 360 and its works one day but when I turn off the game the monitor goes into power saver mode and i have problems getting it back out the next day the sound still works when i start the console up but no picture
Hey fellas,
I just bought the 22" Gateway Monitor and am Having similar problems.
Heres what I found out:
Check the recommended cable input \ outputs for your cards and monitor. I know this 22" says it needs a 24-Pin DVI-D Dual Cable, but works with the others.
I'm currently using a 18-Pin DVI-D Single and think that is the problem. My card supports DVI-I Single and Dual, so I would recommend, for myself, DVI-I Dual Link to make sure it has the max power and signal.
Check to see what cable you are infact using, and go to this website to get some info on DVI-Cables:
http://www.datapro.net/techinfo/dvi_info.html
This is where I found out that I didn't have the cable the monitor required for max input, and might be the solution.
I will post back, but this should get your started.
Posted on Mar 13, 2008
  • JBarbea1 Mar 13, 2008
    Mary_GWER1660 says:I understand that the DVI Mode for this monitor is greyed out. right?
    Jonathan Barbeau says:correct
    Jonathan Barbeau says:yes
    Jonathan Barbeau says:I cannot select DVI Mode on the monitor
    Mary_GWER1660 says:Can you tell me exactly when this started and describe any changes you made around that time?
    Jonathan Barbeau says:Yes. It started Last Night
    Jonathan Barbeau says:I originally configured the monitor with a VGA Cable, then switched to a DVI-D Single Link Cable
    Mary_GWER1660 says:Is your computer using HDMI to connect to DVI?
    Jonathan Barbeau says:My Video card has multiple DVI-I Outputs
    Jonathan Barbeau says:and I am using the DVI-I Output to the DVI Input on the monitor currently
    Mary_GWER1660 says:Has this ever worked before?
    Jonathan Barbeau says:I've only had the monitor 2 days
    Jonathan Barbeau says:and this is the first time I used a DVI Input
    Mary_GWER1660 says:Okay. In connecting the display, use the link below for instructions.
    Mary_GWER1660 sent a link to Connecting the Display[http://support.gateway.com/s/MONITOR/701...]
    Jonathan Barbeau says:I was able to connect the monitor just fine
    Jonathan Barbeau says:and I recieve a display when using the DVI Cable
    Jonathan Barbeau says:I do not get DVI Mode when it is plugged in
    Jonathan Barbeau says:the DVI Mode is Disabled even when I have the DVI Cable Connected Properly
    Jonathan Barbeau says:I will follow these instructions again when I return home, can you answer a cable question for me?
    Mary_GWER1660 says:Sure, As long as it is for DVI cable, should work.
    Jonathan Barbeau says:The current input for the monitor is a 24-Pin DVI-D Dual Link and I am using a DVI-D Single Link Cable
    Jonathan Barbeau says:My Video Card Output supports DVI-I (which is Analog and Digital, the best of both world)
    Jonathan Barbeau says:Does this have an effect on being able to use DVI Mode on the monitor?
    Mary_GWER1660 says:The
    compatible DVI cable should be digital. Check out this link to see the
    type of cable you need: http://support.gateway.com/s/cables/8011...
    Jonathan Barbeau says:I am currently using that cable type
    Jonathan Barbeau says:And I have noticed that it is only the Single Link DVI-D Cable, not the DVI-D Dual Link
    Mary_GWER1660 says:Okay, if you are using this cable type, it should work.
    Jonathan Barbeau says:Monitor Input: 24-Pin DVI-D Dual Link Cable
    Jonathan Barbeau says:Cable Shown: 18-Pin DVI-D Single Link Cable
    Jonathan Barbeau says:does that matter?
    Mary_GWER1660 says:It should be dual
    Jonathan Barbeau says:and would that have an effect on being able to use DVI Mode on the monitor?
    Mary_GWER1660 says:Yes. It may not be recognized properly
    Jonathan Barbeau says:Ok
    Mary_GWER1660 says:I hope the information has adequately addressed your concerns. Is there anything that I can be of help to you?
    will switch the cable to a more efficient cable, the DVI-D Dual Link
    instead of the DVI-D Single Link Cable to ensure proper function. I
    just wanted to clarify.
    Jonathan Barbeau says:You have answered my questions and concerns for the time being.
  • 75 Answers
Try to Lower the resolutionof your monitor.
Posted on Mar 06, 2008
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
What do i have to download to play xbox 360 games on the computer?
Sorry, but you cannot play Xbox 360 games on your computer. If you want to connect your 360 to a computer monitor, you can use HDMI if you monitor supports it or pick up a VGA adapter for the Xbox 360
Mar 06, 2011 | Microsoft Video Game Consoles & Games
How do we connect xbox consul to imac and play
There is no way to connect the original XBox console to an imac's monitor. There was never an hdmi or VGA connector that was worth buying made for the Original XBox.
The XBox 360 has a nice VGA adapter. But no the original XBox, sorry!
Apr 14, 2010 | Microsoft Xbox Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
If you need further help, reach me via phone at https://www.6ya.com/expert/clayton_0b2096930c0c699a
Jun 30, 2009 | Microsoft Xbox 360 Console
Graphics suddenly switches to lower resolution...?
Check to see if you have all cables snug in the individual sockets
and see if you have HDMI, HD Component (RGB cables) or the standard RCA Video Cables (Yellow/S-Video)
check to see if the switch on the cables (standard w/ Xbox) is switched to HDTV or TV.
also, see if you Xbox power is snug, it may cause resets in the Console...(I've had that happen)
Or just try a different video cable/source.
Mar 30, 2009 | Microsoft Xbox 360 Console
Acer AL2416W 24" Monitor switches off and on after a few minutes
open the monitor observe smps capacitor in primary filter may leackage if faulty replace it
Jan 17, 2009 | Acer Al2416WD LCD Monitor
Monitor will no longer display my 360
problem caused by the GPU. I just fixed on the other day. you can fix them like the way you fix the 3 red light issue. you can get the repair kit for like $10. I got my from the site below.
Xbox360 Repair kit
Dec 10, 2008 | Microsoft Xbox 360 Console
Good trouble shooting. So it most likely is the monitor. Can you talk to your vendor about a replacement? There could be a voltage problem feeding the monitor. Is it set for the correct voltage? Can you check the voltage feeding the monitor? Other than that, there is a circuit problem in the monitor.
Sep 20, 2008 | Acer AL1716 17" LCD Monitor
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
Xbox 360 trouble
whenever i turn my xbox on the light around the power button turns from red to green and nothing happens.
Jan 22, 2008 | Trendware TRENDNET 10BT/100BTX KVM...
Computers & Internet Logo
1,519 people viewed this question
Alun Cox
David Payne
David Payne
