Question about Epson Stylus C88 InkJet Photo Printer
Printer will not recgonize cartridgige anymore
The printer says all cartridge I put in are empty and I know they are new. Does the printer have a built in shelf life then dies ?
  • andrecoltrin Mar 02, 2008
    no it is not printing. The driver tells me that I do not have geneuine ink installed. I do.
    even when the printer is not connect to the computer and I turn it off then on the red ink light still comes on.
  • 1,226 Answers
is the printer still print? if yes there is no problem about the message. that message can be rewsolve if you uninstall the drivers of the printer and then restart. after restarting you install back the printer(note: disconnect the printer while uninstalling the printer driver. and also donot connect the printer when installing the driver, when for the comuter told you to do so.)
Hope this help,.
best regards, melnavz
Posted on Mar 02, 2008
  • Emelio Navaja
    Emelio Navaja Mar 02, 2008
    ok, disconnect the printer from the computer and then restaRT THE COMPUTER and connect bact the printer. if not solve then;
    try uninstalling the driver and then restart it again and after restarting install back the driver.
  • Emelio Navaja
    Thats the time you need to clean the entire printer, you disassemble the printer and clean each part, and try to test the circuit board of your printer, Please observe that if some disalignment of the gear this cause an error too.
    If affraid to do so, then you maybe let the repairman do it for you. im sure this will be fixed.
    but first do the unistall and reinstall of the driver.
Printer wont recgonize compatibile cartridges
clean cartridge contacts (both, in printer and cartridge) or change cartridge damaged
Aug 14, 2011 | Epson Stylus CX3810 All-In-One InkJet...
I want to use Black ink only but it will not print because the colors are empty. Do I need to replace all cartridges (LC61) for Brothers print, copy, fax machine. Thanks
If you don't want to replace the color cartridges, you can fool the printer instead. Sensors in the printer shine light through a thin area on the cartridges. The empty (or even just low, even though there may be plenty of ink still inside) cartridges allow the light to get through, the printer sees the empty cartridges, and it won't print anymore. You can cover this part of the cartridge with a piece of black electrical tape to block the light. Voila! No light gets through and the printer thinks you have full cartridges again. This site has pictures showing where to put the tape. I've used this trick on the printer we have here in our office and it works great.
Feb 11, 2011 | Office Equipment & Supplies
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
Hi, I just got a Cannon369 MP360 the black ink is empty,but there is color ink in it. It will not print anything. Do I have to replace the Black to get color in to work??? Since it's 2nd hand I don't want...
With this type of printer you need to have a full black cartridge to print black and white. The new Canon BCI-24 black cartridge from Staples is only $8.29. These cartridges are even cheaper from refillers. I recommend Cartridge World or Office Depot for printer cartridge refills.
Feb 02, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
I just put 2 new ink cartridges in my Canon 210
if your getting this reading directly from the printer ,then I suggest to go where there is a set up button and go for the default setting, with the cartridges already inserted . if reading coming from your comp. , then I suggest to re configure the printer s software. let me know , hope it helps AJ
May 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
Canon pixma mp210 and compatable ink cartridges
Try pushing the reset button for about 5 seconds. This has worked for me.
Oct 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Brother 210C One colour cartridge empty, want to print a black and white fax
Yes, if you dont need the color anymore in future:
You can cheat with empty c/y/m carts by sticking some dark but very thin adhesive tape around the nose (see picture).
After that the printer logic expects the c/y/m carts always as full.
But you cant print any colors within the next 2 weeks anymore because air will dry out the print head (and destroy the color nozzels)!
See brother homepage for instructions on how to print in grayscale only!
Jan 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus C88 InkJet Photo Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
