Question about Korg Legacy Collection
Sticky keys on Korg extreme
I have a few white sticky keys on my korg triton extreme. Can anybody help? please
  • 3 more comments
  • Anonymous Apr 17, 2008
    My F3 Key no longer plays after 1.5 years old. Cannot find anyone who can or is willing to address the sticking and key quit playing problem. There is a repair manual on a CD selling for $20.00 and has only a copy of schematic and korg manuals that do not address the problem either...
  • keysrme1 Aug 20, 2008
    Where can I find an illustration of fixing a broken key on a Korg Triton Extreme. I have broke 4 now and it is getting costly. Please HELP!!!!
  • Anonymous Apr 23, 2009
    I have a broken key, but I don't no what screws to unscrew to replace it! I don't really want to take them all out then end up breaking sumfim. pls help!
  • Anonymous Mar 13, 2014
    My korg triton tr is not powering up what may be the cause of this problem
  • Anonymous Mar 24, 2014
    Sticky keys on korg wavestation
I just changed the key on my Korg Triton Studio 61. It took some time, but it wasn't that hard. You'd better have a power screw driver. I had to take out at least 30 screws.
Do this at your own risk. Don't blame me if you mess up your keyboard. I'm telling you. If you're not that handy, don't try it. Pay attention to detail and be careful.
The Steps that I took
1) Turn your keyboard face down. Make sure you put it on something soft so that you don't scratch the face of your keyboard or damage your knobs or the pitchbender.
2) Remove all the screws on the bottom panel and remove the panel.
3) you have to take the entire keybed out. Lots of screws! I had to remove the "assignable - midi input/output board" to get it out. MAKE SURE THAT YOU DISCONNECT ANY CABLES THAT CONNECT THE KEYBED TO THE REST OF THE KEYBOARD. I had to disconnect the keybed at three different places. These connector cables are NOT strong and if you pull too hard, you WILL break them.
3) Once you get the keybed out, you have to remove the plastic binder that goes at the back of the keybed. It holds the keys in place.
Then Snap the old key out. snap the new key in. Before you unpack your new key, make sure the old one is really broken. I had a key that wasn't broken. It had just come unsnapped. I snapped it back in and it was fine.
Put it all back together again.
I had a broken key before. i got it repaired and it cost me $150. This time I fixed it myself and it cost me $7.50
Posted on Jul 03, 2009
    Scholar:
  • 68 Answers
Unplug the unit. Apply small amounts of isopropyl 99% (or 91% if it contains no emollients) using a dropper or try with a High-Quality cotton swab as you depress and release the key. If it helps, make sure it dries completely. The alcohol will evaporate quite rapidly. Works well for Red Bull and Jaeger Bombs dropped on the keys.
The Triton LE has a similar key structure to the Karma and some Ensoniqs. It is actually VERY EASY to a tech with minimal experience to open it up and clean the contact of a key that has gotten too dirty. Broken keys are also very easy to replace. It is not easy to destroy your keyboard by opening it and taking a look. When you shake it, can you hear a small piece of plastic rattling? Maybe it broke. www dot korgparts dot com has replacement keys and I think even manuals and stuff. FYI - the Triton and LE use different keys.
Posted on Jun 07, 2008
  • Pavel Jun 07, 2008
    Oh, I thought you said LE. The Extreme is simple. The contacts are accessible by removing the back panel only. But you must remove the entire key assembly to replace a broken key. Another thing... after the alcohol, I alway use compressed air to dry it. Hope that helps!
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
Korg triton studio Change voltage input from 110v to 220v
Safest thing is to use a transformer. If it is only 35 watts, that is pretty small.
Often you can find a small "control transformer" that has dual primaries for 120/240 volts.
Connect it as an "Autoformer". In this connection you would only need one thaat would handle half the 35 watts... However, the smallest is probably 5 watts giving lots of capabilty. Google "autoformer" to see how to connect it. Essentially the primaries go in series and you take you 110 from one-half this combination.
The secondary of a control transformer used this way would NOT be used but just taped for insulation.
You might contact a heat and ventilation company as they may have one... even one that was removed for very low cost.
Aug 15, 2009 | Korg TR76 76 Key Synthesizer Workstation
Battery voltage ic is low for triton extreme what is this
Pry off the small round plate underneath your Triton and stick in a CR2032 Battery
TRITON Extreme Operation Guide
Jun 11, 2009 | Korg TR76 76 Key Synthesizer Workstation
Korg trition worksttaion 76 key
necesito el manual de servicios del korg extreme 76
Jul 19, 2008 | Korg Legacy Collection
Computers & Internet Logo
1,957 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Hardware and...
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
