Question about Grundig G4000A FM/AM Radio
G4000A my G4000A radio flashes batt check with new batteries
    Problem Solver:
  • 6 Answers
Once you turn the unit on, the battery indicator should disappear. Make sure the batteries are inserted correctly. With six AAs, I've put them in backwards on more than one occasion.
Hope this helps.
Posted on Jan 11, 2009
Satellit 800-batt blinks w/new Duracell alkaline batteries.
Have you checked the voltage on the new batteries.??? Some batteries, even if they are new... have a short shelf life, if they aren't used. You will need a volt meter or battery tester...if you dont have either, take the batteries to a Radio Shack or even a Auto store and ask them to check it for you.
Oct 20, 2014 | Cameras
Reset timer on g4000a
HOW TO SET THE SLEEP TIMER
Press the
SLEEP
button over and over. Each press
changes the amount of time the radio will play before
shutting off automatically, 60 through 0 minutes.
To make the radio work without a timer, try pressing the ON button longer than you usually do.
Dec 02, 2013 | Grundig G4000A FM/AM Radio
Radio works on ac power but not on batt power
"Radio works on ac power but not on batt power AA batt seams to be ok" The AA battery is only for the radio memory and clock. Have you put a battery from your drill in the radio? if so check fuse inside radio.
Sep 13, 2009 | Dewalt DC011 AM/FM Radio
How can I get a manual for the Grundig G4000A?
Here is the link to eton corp for your manual
Hope it helps.
Sep 09, 2009 | Grundig G4000A FM/AM Radio
Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Aug 06, 2009 | Dewalt DC011 AM/FM Radio
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
Apr 04, 2009 | 2001 Dodge Neon
Clock
Radio can be on or off. 24 hour clock only (11:00pm = 23:00hrs). 2 clocks Time I and Time II. Select one or the other by pressing TIME 1/2 button (shows in display at top center). To set, if it is 23:00hrs, press 2 3 . 0 0, then immediately press TIME 1/2 button.
Nov 11, 2007 | Grundig G4000A FM/AM Radio
AM reception
If the internal antenna is broken that means the ferrite bar is broken,that does imply that the wiring around it is cut. If the two parts are not removed, the antenna may still be able to perform correctly (just as two magnets put end to end). You can try to put it in the vicinity of another radio to see if there is any resonance effect.
Hope it helps.
Oct 30, 2007 | Grundig G4000A FM/AM Radio
Grundig G4000A FM/AM Radio Logo
167 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
