Question about Olympus DM-10 Digital Voice Recorder
Download Files I am trying to download a file to my PC. I get an error message "The Job No. File is not in the program download folder or is being used by another program."
  • Anonymous Nov 28, 2008
    works for admin, not user of computer.
    solution?
  • Anonymous Feb 20, 2009
Hi, I had this problem using a Olympus DS-2300 recorder. I installed the DSS Player Software on my PC and when I tried to download the files from my device to the PC I had this problem.
You will need to check the location of a file called DSSjobNo.dat. The application I think tries to copy this file into the default location for the Download folder, usually somewhere in your My Documents. If it can't copy the file there for some reason then that will stuff things up.
To check where the application is expecting the file you will need to check a value in the registry. This maybe a little tricky so get someone who knows there way around the registry to help you. The location of the entry is HKCU\Software\Olympus\DSSPlayer2002\Dictation Module\download\InstallSetting The value is JobNoFilePath and will hold the path to where the application is expecting the dssjobno.dat file.
Armed with this knowledge you can then check if the dssjobNo.dat file is in that location. If not copy the file from C:\program Files\olympus\DssPlayer (this is where I found the file on my PC) to the location the registry entry specified.
Or if you know what you are doing you can change the reg entry to go to the location you want the file to be in. Useful in my case as I wanted the download path for my files to be on a shared folder on the network and I wanted to keep it all together.
Hope this helps!
Posted on Feb 27, 2009
Corrupt Outlook Express 6 .DBX File
You might use following methods, short guide from Microsoft below and if your corruption is severe check this out https://outlookexpress.recoverytoolbox.com/ Recovery Toolbox for Outlook Express
1) Identify all the .DBX files (folders) that you are going to restore but which do not exist yet on the new machine. This list of files would only include folders that you have created yourself and would not include folders like inbox, outbox, etc.
2) Start Outlook Express and create a new folder for each one you identified in (1).
3) For each new folder you have created you *must* highlight it - select it with your mouse as if you were going to see what is inside it. We know it is empty, but Outlook Express will not create the .dbx file until you do this. [Thanks to Ethan and "Biggles" separately for their input]
4) Close Outlook Express. Now you will see that your Outlook Express installation will have a .DBX file for every folder you are about to restore.
5) Now restore the .DBX files - that is you replace the empty dbx files created in 2 and 3 with the files from your backup.
6) If you restored from CD it may be that the read attribute on the files has been set. In this case you will need to ensure that the read attribute is cleared for each file you restored (right-click on the file and choose "Properties"). [Contributed by Aaron Kuhn]
7) If all is well, when you open Outlook Express now you will get all your restored messages.
If you receive a message in your message body window "cannot display folder, you may be out of memory or disk space" after restoring, then it is likely you missed step 6. Go back and ensure your DBX files are NOT set to Read-Only.
Jun 28, 2015 | Microsoft Outlook Express
Tip
How to delete files that are used by other programs in windows XP/Vista?
Today tip will help you to delete the files and folders that are being used by another programs and applications, for example a virus affected file. You have tried to delete such kind of files or folders and received the any following messages.
· Cannot delete file: the file is in use by the other program
· Cannot delete file: There has been a sharing violation
· Cannot delete file: The file is in use by another program or user
· Cannot delete file: Disk is not full or write-protected and that the file is not currently in use.
· Cannot delete file: The source or destination file may be in use
Normally, a windows restart will allow you to delete such files or folders that are being used by other program, but if you want to manage it without restart your computer then simply you need to download a freeware tool called Unlocker.
You can download this tool for any windows version using Unlocker link. Download it and run the easy setup.
After installation, right click on file or folder that you want to delete and select the option Unlocker.
If your requested file or folder is used or locked by other application then a small window listing of lockers will appear.
Here simply click on “Unlock All” button and now you can easily delete this file.
Thanks,
Bhautesh.
on Feb 23, 2010 | Computers & Internet
"how to fix error code 0x80040702
The 0x80040702 error is common on computers on which you are trying to install a game or piece of software. The error will show for a variety of different reasons, but is almost always shown when you are installing something on your PC. There are several causes of this problem and several ways to fix it, depending on the cause. Here's what you need to do to fix it...
The biggest reason why this error appears is because of missing DLL files on your system. To fix this, you must first see if your PC has any of the missing DLL files on your PC and if it does, then put that file in the right place. To do this, click on Start > Search. Then search for the filename the installer claims is missing. If any results come up, then copy the file into the C:\Windows\System32 folder of your PC. If there are not any files with that name on your system, you should search for " download" on Google, download the file and put it into the C:\Windows\System 32 folder. This should cure the problem.
If that method does not resolve the issue, you should then perform a clean out of any leftover settings that previous installs might have left. To do this, browse to C:\Program Files\ and delete all the files inside that folder, clean out your PC with a registry cleaner and restart your PC. This should stop the error if it appears when you try to perform an upgrade, repair or reinstall of your software.
If these don't work, you might have a virus infecting the files or settings the program needs to install. To combat this problem, you should download an antivirus program and then install it on your PC, allowing it to scan your system. It will find and remove all the infections on your computer, which might stop the error from appearing.
Article Source: http://EzineArticles.com/4122823
Apr 04, 2014 | Computers & Internet
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I am trying to download skype for my laptop. I keep getting the error 1618. I have restarted my computer and tryed to find any files on my registry, but still no luck
Download ccleaner and run it.
After that, at the RUN menu
type "temp"
And; type %temp%
Delete all the temp. files and folders present.
Before downloading the latest version of skype
Delete any file related to skype.
You can check in C:\Program Files\Skype....
ok
try this
Feb 21, 2010 | Skype IM
When I try to download Java, I get the error message #25099 - Error unzipping core files. The fix tells me to remove C:Program FilesJavajre6. However, I cannot locate this file anywhere to remove it. Can...
If you are using windows xp, go to Start - Search, on the left panel, select all files and folders, under "All or part of the file name" type in Javajre6. See if that helps.
Nov 08, 2009 | Gateway Computers & Internet
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
2. Backup the old version of the DLL file.
3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
Transferring MP3 files from PC "C" drive "My Music" folder to SD card
you may want to try downloading only those that didn't download the first time. Sometimes when you try to download a large file (all the songs) it causes the "error message" you talk about. You may want to delete files already downloaded, or save the files downloaded to a different file folder, and try the download again.
Dec 27, 2007 | iLO (2 GB) MP3 Player
Olympus DM-10 Digital Voice Recorder Logo
2,244 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
