Question about Dryers
My LG gas dryer DLG5988W
My dryer when I turn it on, "hums" instead of turning on. The lights go on but it doesn't actually start drying or giving me an error code.
Lint filter is clean.
Thanks for any assistance
K
I need screen filter dryer for dlg5988w
Posted on Mar 02, 2008
    President:
  • Dryers Master
  • 2,651 Answers
Somethin might stuck down insinde the channel where the llint filter goes, small sock baby tee or somethin to that effect, it rests against fan and prevents motor from turning, usually lookin down with a flashlight will confirm this
Where can i get parts for an LG gas dryer number DLG5988W
http://www.repairclinic.com/Shop-For-Parts/a8b200d684294/Model-DLG5988W-LG-Dryer-Parts
Sep 08, 2014 | LG DLG5988 Gas Dryer
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
LG Gas Dryer (Model # DLG5988W) is not heating, the gas is not turning on. When the dryer is turned on the ''Check Filter'' light comes on and when switching to a drying cycle the ?Cool? light is always...
The dryer has a resettable SAFETY thermostat located on the flame tube inside the dryer. LG recommends replacing the Safety and High limit thermostats if the Safety thermostat is tripped. The dryer Glow bar igniter could be bad as well as the gas valve or Main computer. Time to have the dryer serviced by a qualified LG tech. LG has factory service tech in most large cities. Give them a call at 1 800 243-0000.
Hope this helps.
Mike
Oct 31, 2017 | LG Dryers
LG DLG5988W Gas Dryer (NO HEAT)
I'm pretty sure that the cooling light is always on and blinks when it is cooling. I look at my brother's and he has the EQ bar and it acts the same.
Dec 04, 2007 | LG DLG5988 Gas Dryer
LG DLG5988W DRyER NOT DRYING
Sounds like you have solved your problem.
Sep 26, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
338 people viewed this question
Top Dryers Experts
