Question about Coby MP-C7085 MP3 Player
Coby mpc7095 mp3 player
Battery will not hold charge over 1 or 2 hours
  • 4 more comments
  • Anonymous Mar 13, 2008
    this device won't charge at all.
  • rdrexler2 Apr 05, 2008
    Won't hold a charge very well at all, including when sitting off for a day or two. Not sure if it's worth replacing the battery (if possible) or if there's any solution.
  • Anonymous Apr 09, 2008
    I'm having a similar problem, and I did charge it for more than 2 hours. What's the resolution to this problem?
  • Anonymous Apr 26, 2008
    I Have the same problem is there any way to fix it
  • timnewby Sep 08, 2008
    This was the response I revieved from Coby when I determined my battery was no longer any good. I had to remove the 2 tiny screws at the bottom of the unit then pull the silver case edge over the USB & headphone port this allows you to see the battery. Now you can cut the existing wires and then use heatshrink tubing to connect the new battery or take a soldering iron and briefely touch the contacts where they are soldered to the board to remove the old battery and then solder the new battery to the board. The second option was to take it to a local Best buy store to have it replaced I was told it would be between $10 & $15 for them to do it.
    "To obtain a replacement part (Remote, AC Cord, DC Cord, Headphone, … etc), please MAIL the following information to us:
    1) A note stating the model number
    2) The requested part
    3) Full Name, Return address & phone number.
    4) $ 6.00 Money Order ONLY for each part
    Send correspondence and packages to:
    COBY Electronics Corp.
    Customer Service
    56-65 Rust Street
    Maspeth NY 11378
    Sincerely,
    Technical Support
    techsupport@cobyusa.com"
  • Anonymous Mar 13, 2014
    after i have charged the player.i turn it on and the battery is dead
Try resetting the device while plugged into your computer... also some of the pins might be bent inside de port of the player, make sure they are correctly set with a flat, small tool, what do you have to lose?
Posted on Apr 14, 2008
I have a coby mpc7095. When I try to download music or videos the computer says device not found.
How do i correct this problem
Posted on Apr 10, 2008
It dont play my ******* song
Posted on Mar 17, 2008
My Coby mp3 2 gb model number MPC7095 wont turn on
1 Unplug anything that is connected to the player. This includes headphones, power cables and USB cables.
2 Locate the reset hole on the back of the player. This is a tiny opening in the bottom right corner on the back of the device that features a recessed button that will reset the device.
3 Insert a pin or other long, thin needle into the reset hole.
4 Press and hold the reset button for a few moments until the device resets. The screen will reset and the player will be restored to its original setup.
Apr 17, 2012 | Coby Audio Players & Recorders
It is not included coby mpc7095
All support for Coby players is on cobyusa.com .
Enter this phrase in the address bar of Internet Explorer.
Next enter MPC7095 in the Product Search box, top right and the support for this player will show up.
Transfers onto this player can be made by:
1. Using Windows Media Player 11 : look in the Setup Guide .
2. Exploring 'My Computer': use the copy and paste or drag and drop method to transfer files. note: Files put in the Media folder can be reached within in the player. Files put in the Data folder, can be viewed only when connecting to a computer.
Jul 18, 2010 | Coby MP-705 Digital Media Player
Plz help
it am very sorry
Sep 04, 2009 | Coby MP-C7085 MP3 Player
Coby mp4 shuts off after about 7 mins
I had the same problems with my player i took it apart and there was a little chip connected to the battery terminal wires, i removed the little black chip which is a sensor for the batteries to prevent damage to the unit and I removed it and resoldered the wires the battery terminals and now it works perfect.
May 10, 2009 | Coby MP-C7097 MP3 Player
My coby mp3 mpc7095 will charge
i would restart it when turning it on becuase myne doesnt turn on when i push the on button i have to restart it and all my songs are still there tho time isnt but who care i got music and it basicaly sumerged in some liquid i think is tea a week ago
Mar 12, 2009 | Coby MP-C7085 MP3 Player
Mpc7095 mp3 player
Try to format it from your computer the same way that you would if you were formating a floppy disk
Jul 12, 2008 | Coby MP-C7085 MP3 Player
Model no. mpc7095 coby mp4 does not turn on
Make sure the hold switch is turned off..that will restrict you from turning it on, besides that, the battery is not holding a charge, you will need a warranty replacement, please call:
Toll-free: 800-688-2629
May 20, 2008 | Coby MP-C7097 MP3 Player
Help with my mp3
plug your usb to your computer and try to see if your computer can detect it.
then you can try and reset it again.
good luck
May 20, 2008 | Coby MP-C7085 MP3 Player
My mpc7095 wont turn on
Mine is the same way, i just bought it and it wont turn on at all. im a little irritated because i wasted money on it if its not going to work, can anybody help ??
Apr 21, 2008 | Coby MP-C7085 MP3 Player
Coby mpc7095
Hmm... I'm not sure if this will work but it did when mine wouldn't work. Just go to settings at the bottom and choose usb mode and select mpc, that should solve your problem
Apr 10, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
904 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
