My samsung media player yp-t9j will not turn on and the usb wont charge it HELP!!!!
Sponsored Links
Same Problem
Jan 25, 2009
-   when i want to turn it ,,on'' it doesn't start the display is O.K because i can't hear anything what can i do?
-   Guest
Apr 11, 2008
-   for some reason my mp3 behave the same. it wont turn on and when i plug it into the usb port, nothing happen. wat happened? i really dont want to buy a new mp3 now...-   nguye862
Mar 28, 2008
-   My YP-T9 worked perfectly for quite a while, but the other day, after charging it, I tried to turn it on with the "Hold" button on. The "Hold" symbol popped up on the screen, and I accidentally hit the control pad with my thumb. The screen went off, and even after the Hold button was turned off the unit would not power on. Now the unit will not charge either. I hope that this is a fluke and I accidentally turned on some secret lock mode. Can anyone help me?-   HuangFeiHong
Mar 28, 2008
-   OMG, mine too. I went to the troubleshooting page on Samsung.com and it suggested the cable was defective. However, I cannot seem to find out where I can buy a new cable.-   Guest
Mar 26, 2008
-   my samsung yp-t9j does not charge also it does not turn on i was working this morning and now it does not, please help me-   Guest
You can reset the mp3 player by holding down the "menu" button and the "a/b" button together for a few seconds then push the power button and it should turn on. Mine was doing the same thing and this worked.
Couckie's solution was perfect I was stwitching my player off and couldnt restart it. I tried charging and nothing on the screen.
Following the solution, it worked and is as new again! many thanks, I was getting panicke dthat it had died on me! a great little player, samsung don't make them this small at all!
That worked for me, too. first, connect to the USB for a while to charge (even though there is nothing on the screen. Second, hold the (rec a/b) key and the (Menu) key down at the same time for 15 seconds. Third, press the play button to power up as usual.
have had my mp3 player for three years, now it will not power on at all. where can i go to have a...
(More)
have had my mp3 player for three years, now it will not power on at all. where can i go to have a new battery installed?
My computer recognizes my mp3, and it will light up whenever its charging... but it will not turn on...
(More)
My computer recognizes my mp3, and it will light up whenever its charging... but it will not turn on when I want to listen to music. The screen stays black unless if its charging. Any Ideas? oh yea, I already tried reseting it.
