Question about Logitech Quickcam Chat Webcam
Quick cam have set it up but don't know what to do next
  • Anonymous Mar 26, 2008
    not functioning
    President:
  • 8,637 Answers
Download Skype and install it and then read below how to setup the Audio and Video for Skype so uyou can talk to family and friends.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
Unable to set up quick set up guide for A4 tech Model PK-5 view cam
1st You download Webcam Driver.
A4 tech cam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Nov 22, 2013 | A4tech Xmaster PK-835 Webcam
Wireless cam I don't know what brand I'm trying to set it up
Well, I think you can get the best answer by searching on Google...
Mar 03, 2013 | Home Security
Pings at any timing adjustment not using cheap gas 96 in stroker
If you're running a 96 in stroker, you're probably running a hot cam as well. In this instance, I'd set the front cylinder advanced timing to no more than 33° maximum advance. Somewhere between 30° and 33° is where I'd set it. Also, if you're running over a 9.5 to 1 compression ratio, I'd run some sort of fuel additive even in high octane pump fuel. The fuel we have today is lousy, not like it used to be years ago. I just built an 89 in, stroker with a 3 Suns cam, Head-Quarter's modified heads, and 10:1 compression. It dynos out at a 98 HP with 95 FT. Lbs of torque. We have to mix the fuel half and half high test gasoline and 101 octane racing fuel to prevent pinging. If you're running an aftermarket ignition system, make sure you don't have your "rate of advance" switch set to advance your timing too quickly. To set this, start at the slowest rate of advance setting on the ignition system. Ride the bike and see if it spark knocks. Advance the setting one notch at the time until you get spark knock and then go back to the highest setting in which you didn't get any knock. Do not confuse intake noise with spark knock. I know it sounds silly but I had a guy drive me nuts doing that once. When he'd open the throttle, he'd hear the intake noise and thought it was spark knock. The clue came when he said that it spark knocked even at idle. Do What? Then I knew what he was hearing. The long overlay grind of the cam was making a noise that he was hearing coming out of the intake. LOL. So, ****** the timing a couple of degrees off of maximum, boost your octane, and make sure your rate of advance is not too quick. If you have an igniton system and don't have the instructions, go to their manufacturers website. Usually you can download and print out the installation and setup instructions.
Good Luck
Steve
Jun 01, 2011 | Harley Davidson FLSTC Heritage Softail...
I have no cd to download my quick cam
Unplug your cam
uninstall any current webcam software
restart your computer
visit the logitech website - identify your cam and click on the picture
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
download the installer.
run the installation set up and note the options - you may not want the Logitech Chat but the Desktop icon is a must.
Note - you will also need DirectX download to support your webcam - this is probably covered in the installer
Connect your webcam when prompted.
Jul 08, 2010 | Logitech QuickCam Messenger Web Camera
I downloaded my Logitech Quick Cam after switching
Disconnect the camera, start in Safe Mode and go to Device Manager. In there disable the camera and try to uninstall its driver. Next delete manually all files and folders relating to it. Reboot again in Safe Mode and run a registry cleaner like Eusing.
Finally uninstall it in Programs.
Mar 04, 2010 | Logitech Webcam
How to install logitech quick cam to pc
You'll have to install driver for this web cam which CD comes with web cam pack.
This CD insert in your CD drive
Then its runs automatically
after that you click on install driver for web cam
then click on next and then select yes on license and agreement console and the click next and at last click on finish.
Regards
Ashly
Feb 05, 2010 | Logitech Quickcam Chat Webcam
"error 2178 logitech quick cam pro 9000 installation"..cant insta
Normal 0 Double click on this site
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Then
Search by Image (Match what yours looks like)
or
Search by Name
and
Product Name.
This will then take you to the next window where you need to select your
Operating System
. Then you will get your download driver.
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
Hopethis helps. Bud
Mar 31, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logitech Quick cam E2500 Series..
i need a sofware to install my cam
Nov 03, 2008 | Logitech Webcam
Webcam not working in windows vista
this is most likely a settings issue with your video in vista control panel, not the webcams.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Logitech Quickcam Chat Webcam Logo
29 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
