Question about Harman Kardon DPR 2005 Receiver
RF channel is messed u
Right front channel/speaker has constant buzz/fuzz/static -shhhhhhhhhh-. Checked speakers and source. All other channels are okay
  • diou123 Apr 15, 2008
    my DPR2005 open a few second (5) and turn off after, the led is amber at off and blue a few second... I receive a receiver by fedex... transport trouble??
  • 382 Answers
Problem is it is a common problem. I have one with the same thing, it appears as though HK discoed the line for a reason and sold them all at half price in Costco.
Posted on Jan 15, 2010
Had the unfortunate occurance of this recently too. Dropped it into my freindly HK repair agent and now have to look forward to an 8 week (total) wait and a large bill to boot to replace the amplifier module. It was either this or the preamp stage. Fortunatley they quoted 'it wasnt a common problem'
Posted on Sep 05, 2009
No sound from Surround Back Right (SBR).
Bad wire, bad speaker or bad channel. Disconnect the wire from the amp. Using a 1.5v battery touch the wires to the battery briefly. You should get a pop from the speaker. If not get a different piece of wire and use it instead of the regular wire. If still no pop then the speaker is bad.
Aug 17, 2016 | Pioneer VSX921K 71 Channels Receiver
Sansui AU-D33 Lh speaker channel not working.
As the channels are identical you can use the good channel has a guide to the bad one. First thing is to look around see if anything does not look the same as the right channel.
If nothing obvious stands out, with the power on, using an insulated screwdriver touch the two channels one at a time. Keep away from the power supply and anything that is common to both channels. The channel will buzz once touched. Depending which points you touch them. The right channel will tell you if it should buzz at that point. Work backwards from the speaker outputs if you can. If you hear a buzz on the left channel then it is working at that point, if it produces the same sound on the right.
Using this method you should track down the part that has gone.
Dec 11, 2015 | Audio Players & Recorders
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
Harman Kardon DPR 2005 Receiver Logo
281 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
