Question about Toshiba Satellite P105-S6104 Notebook
Laptop booting problem
windows doesn't boot. looks like some files are corrupted in registry. could you please help me fix this.
Regards,
Paul
    Guru:
  • 377 Answers
Dear sippy
the problem , maybe causing your memory have a problem with other peripheral or onboard vga, try make your USB 2.0 off by setting bios and when you installing windows XP you can push F5 key rapidly , untill you can find two option, you have to choice first option and try to finished the installation.
i hope your problem can solved
thanks
cropp
Posted on Mar 15, 2008
I had this with my desktop pc, the only way I could get around it was to totaly reinstall the windows operating system, the only problem with this is you lose all your files on your pc.
Posted on Mar 02, 2008
I have a Dell Inspiron 1525 stuck in windows boot manager file \windows\system32\config\system status: 0xc000014c info: windows failed to load because the system registry file is missing or corrupt ...
Here's part of an article on how to replace that registry file:
Look in the C:\windows\system32\config\regback\ folder.
There should be copies of the registry files stored inside that folder.
They are backed up periodically and stored in that folder.
If you create a MiniWin, BartPE, or a Linux Live CD, you can start the computer from CD and move the file system to the required folder, C:\windows\system32\config\.
Apr 15, 2013 | Dell Inspiron 1525 Laptop Computer PC...
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
Windows could not start because the following file is missing or corrupt: <windows root>\system32\hal.dll. How do i fix it?
hi, right you need to boot up using your windows disk, change the boot order so it picks your DVD drive first, now select repair once windows starts up.
Regards
GeWiz.
Please rate this if it helps.
Dec 18, 2010 | Acer Aspire 1640Z Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Blue screen: Stop: c0000218 {Registry File
Hi.
You would have to have the operating system repaired or completely re-installed.
Please rate me. Thank You.
Apr 16, 2009 | Acer Aspire 5315 Notebook
Sony laptop VGN-N130G will not boot.
use any windows xp disk boot from it and use R key to repair windows then type fixboot
if helped rate fixya
Jan 05, 2009 | Sony VAIO VGN-N130G/W Notebook
It won't boot
Hello maybelle,
Your system is corrupted, files needed to boot up windows was corrupt or it was deleted accidentally, the only solution that can correct the problem is provide installation disc(windows installer) and insert it to the CD ROM and boot your system to CD DOM and follow the the on screen instruction.
(note: installation of Operating system can lost your important files, back up the files)
installation of OS refer to this info: http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
please do not rate me if the solution not solve the problem.
if need more info, please notify me, i will give you more information.
best regards.
Apr 09, 2008 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satellite P105-S6104 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
