Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Dryer with Airflow problem
We have a Kenmore Elite Oasis Electric Dryer model # 110.6703. It is almost 2 years old and on the display unit the letters AF came up. I looked in the manual and that means airflow problem. I have removed the back of the unit to clean out any lint and thoroughly cleaned the lint area, as well has cleaned the line. When I turned the machine on with the line unattached, there was little airflow. Without clothes in it it will run the full cycle but as soon as I put wet clothes in the AF appears. Any ideas? Help! Thanks.
Sincerely,
Spencer
  • 1 more comment
  • rlcarter460 Apr 07, 2008
    same code AF removed lint sceen holder cleaaned same code
  • kc2sweet4ne1 Sep 25, 2008
    I bought this dryer and within a week, Sears had to bring me a new one~ but they did it kicking and screaming. I had to get VERY assertive on the phone and threaten to call the BBB. We had the replacement dryer about a week and had to call them back out to fix something with the air flow. It is now 9 months later and we are having the airflow issue again. This product truly sucks and it's not a cheap purchase either. I will never buy anything from Sears again because of the customer service and I will definitely do my research on my next dryer purchase.
  • Anonymous May 18, 2009
    my oasis dryer beep beep AF DELVIA BUCHANAN
Same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Posted on Apr 07, 2008
    Problem Solver:
Thank you, Rlcarter! After reading your solution my husband took the back panel off and explored to find that that was indeed the problem. He fixed and now dryer works perfectly again.
Posted on Jun 14, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Did you try removing lower access panel from front of unit. this will give you acees to the main lint filter housing. a few 1/4 in screws will take it down and loook in theer for blockage.. and althoughyour vent line is clear did you check where ei exits house outside housing can become blocked as well
Posted on Mar 02, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
HI I HAVE A KENMORE ELITE OASIS ELECTRIC DRYER MODEL 110.6708 I KEEP GETTING A F44 FAULT CODE WHAT IS THIS FOR ?
44 flashes if the motor control detects a low voltage condition.
This error code could also be caused by poor air flow, loose wiring harness or a malfunction of the electronic control board.
You can disconnect the vent hose from the back of the dryer & compare that airflow to the airflow at the outside damper, they should be almost the same.
If you have a multimeter and the ability to safely check the voltage at the dryer outlet, you can check for 120 volts at the outlet for the dryer.
If the voltage is low or drops when the dryer is running, this is causing your problem.
You could have a loose wiring connection.
If the outlet voltage is okay, you could have a wiring connection problem between the outlet and the control board of the dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Dryer displaying erroneous letters
AF is restricted airflow clean lint filter and check your vent hose for kinks or obstuctions
Dec 02, 2008 | Kenmore 67082 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
2,672 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
