Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Dryer Doesn't Dry Well: Take two full drying cycles.
I had a repair guy out to fix the problem. He verified the dryer is getting up to the right temperature, but this still did not fix the problem.
Any suggestions?
I did not install it. Is there anything regarding the installation that might cause the problem? The vent goes down through the floor to the basement, then to the outside from there.
Thanks in advance.
  • Marikie Mar 08, 2008
    Thank you. This proved that the problem was venting and you put me on the right track. I've read up on how to properly vent dryers and will be changing how this one is currently vented.
    Thanks again for the help.
  • Anonymous Dec 31, 2008
    I replaced the thermal fuse in the back two times and it dried the clothes for a few times. Now my dryer only gets hot every now and again. I can't figure out what to do.
    President:
  • Frigidaire Master
  • 2,651 Answers
If at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Posted on Mar 02, 2008
I NEED TO KNOW HOW TO CHANGE THE DRYER BELT
Posted on Jul 10, 2009
We have Frigidaire stackable GLET1031CS0 in three of our rental properties. The homes are new. We had the same problem. The venting in the homes were within specs for this unit. After MANY hours with Frigidaire and their repair people, we finally threatened legal action. One of the main engineers with Frigidaire called our builder. He suggested using NON-FLEXIBLE venting from the dryer to the wall. Something about back draft. IT WORKED!!!!!! Hope this helps!!!
Posted on Jul 26, 2008
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Tip
How to receive the best dryer repair help on FixYa
There are a couple of things that you should include in your dryer repair question so you receive the quickest and most accurate answers.
1. Model Number
The model number can be located on the model/serial number tag that is located on the dryer.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dryers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dryer.
Descriptions like 'My dryer don't work' is not very helpful.
Describe what is not working. For example is the not heating? Maybe the dryer is heating, but takes a long time to dry?
The more details you can give the better. Instead of saying 'The dryer is heating, but takes a long time to dry' you could go into more detail and say something like...
"I put a load of cloths in my dryer and set it on the auto dry cycle. When I went to take them out two hours later the dryer was still running. The cloths were still a bit damp too. Most of the time I can dry a load of cloths this size in one hour. Why is my dryer taking so long to dry?"
Following these couple tips can help you get a faster and more accurate reply to your dryer repair question.
on Aug 03, 2011 | Dryers
Dryer takes 2 or 3 cycles to dry
A Whirlpool dryer either heats or doesn't heat . This problem is an indication of a blocked vent hose , from the rear of the dryer to the outside vent outlet . Try removing the vent hose from the back of the dryer and dry a load , to verify this problem . Wet lint inside the hose also means the air cannot escape to the outside .
Apr 18, 2010 | Whirlpool LER4634J Electric Dryer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
My dryer takes 3-4 full drying cycles to completely dry.
Since you do have some drying hapening, it is probably a lack of total heat.
Most all dryers have 2 heating elements. One for low heat and both for hi heat. Sounds like you lost one of the elements.
On electric dryers, look for:
1. Safety device has tripped and not reset or has malfunctioned.
2. An element has burnt out. Or a wire to the element has fell off or burnt off due to loose connection.
3. Exhaust system is clogged or restricted, causing safety to active. This stops the heating process. (Don't forget the internals of the unit being clogged too.)
4. Not getting full power to the unit. Reset breaker and verify that full power is to the unit.
(Usually somewhere between 208 to 240 volts, depending on where you are at and the manufacturer of the machine.)
5. Timer has malfunctioned and needs replacement. This does effect power to the elements.
Check these out and let me know how you come out.
Please keep in mind that there is the possibility that a new unit may be cheaper than repairing the one you have. New units have warnanties too.
Choose wisely grasshopper. And Good Luck on your getting it going.
May 11, 2009 | Dryers
Drying cycles taking way to long
ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
Nov 25, 2008 | LG DLE2532W Electric Dryer
Dryer doesn't dry very well.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Why are you talking about it rather than acting on it?
You need service to fix it or perhaps if its old trash it and buy new!NOT MAGIC CHEF!
If you buy for price only you will change APPLIANCES EVERY 5 YEARS!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Magic Chef CYE4000AWW Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
2,029 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
