Question about Whirlpool GSX9885J Top Load Washer
Machine makes washing and draining sounds without the pressing power
Machine sounds as if it washing and draining but power is switch is off. I have to disconnect the power cord to stop the machine
    Genius:
  • 3,587 Answers
The switch is most likely shorted..comes from corrosion or simply having water seep into the panel.
Posted on Mar 02, 2008
How to get spin only on this machine. Which letter is it
What machine do you have? Make and Model number.
Feb 04, 2016 | Washing Machines
Machine sticks and 'timer saver' flashes. When turned off and onto 'drain' the lights shown on the video flash.
Switch off machine for an hour, press down all the panel buttons to drain any residual voltage to the board. Now when the power is reconnected and the machine is switched on, press down Start/Stop/Pause buttons.
If the fault does not clear, then check for dirt in the inlet and outlet , check flow and drain without water accumulating within. If not the control board is a suspect
Jan 04, 2013 | Washing Machines
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have an asko w6021 washing machine that won't run. All it does is when the power on button is pushed, and nothing else, it makes a humming sound almost like it's in the middle of the wash cycle. Also you...
Open the hatch at the bottom left of the unit. If there is water still is machine, remove the drain hose and drain machine. Open the drain pump and check for foreign objects, make sure that the rotor spins freely and that there is nothing holding it. This will prevent the machine from working properly
Mar 13, 2011 | Asko W6021 Front Load Washer
Machine will not drain or spin
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Un plug the washer again for 30 seconds plug back in press the start/pause button then press power...This will try to reset your washer.. If it didnt work your pump must be checked...
Apr 19, 2010 | Roper RAS8445KQ Top Load Washer
Machine washes but will not drain water
Make sure the door switch is engaging and making contact as most washers will fill and wash with door switch open but will not drain or spin without doorswitch engaged as the manufacturer does'nt want you sticking your hand in the machine while it's spinning out.
Dec 19, 2009 | Washing Machines
My washing machine displays the word "SUDS" in the box and will not spin
you are over soaping
use only 1 tblsp per load
to clear this issue
do 2 loads without soap
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Mar 25, 2008 | Washing Machines
Whirlpool GSX9885J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
