Question about Gestetner DSc332 Copier
Ricoh 1022 - Error SC320
Hi there
I have a Ricoh 1022 with an error SC320. I know this refers to the 'Polygon Moter' I am an amature and don't know where this part is inside my machine. How do i find it and fix it?
Simple step by step guide is preferred.
Thanks for your help again.
  • jwallpro1 Feb 10, 2009
    display on my gestetner 1802d indicates functional problem SC320 error
    It suggests I turn it off and on again. this has not been successful even unplugging and restarting has resulted in same display error
    What is a functional problem anyway?
  • Anonymous Mar 22, 2014
    still the code in i have reset polygon motor work
  • 38 Answers
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
Posted on Mar 02, 2008
How do I solve SC: 320 Error in Ricoh 161L
SC320 is the laser polygon mirror motor error. It does not reach the right speed. repair or replace laser unit.
Sep 11, 2017 | Ricoh Office Equipment & Supplies
Error message: sc320 can I replace it myself?
sc320 mostly defective in polygon motor you can change by your self if you know how to remove the laser unit , it easy .
Jan 06, 2011 | Ricoh Aficio 1018D Copier
SC320
Polygon motor error:
Polygon motor Defective
SBCU board Defective
Or bad connection between them
Dec 30, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
Sc320
Pleas change the polygon scanner motor
Dec 16, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
When my ricoh afico 1018 printor is on error corde desplay sc320?
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
Sep 13, 2010 | Ricoh Aficio 1018 Printer
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Polygon mirror motor defective
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Got problem with aficio250
Another thing that can happen to cause a jam when you are printing on there is to make sure that the paper size if correct and matches the trays you are printing to. That condition will happen if the printer tries to print a legal size page and you only have letter paper installed in the trays.
Check your settings in the printer control panel to make sure that the trays match and are correct.
Make sure that the green paper setting knobs match the correct tray size as well.
Jun 19, 2008 | Ricoh Aficio 250 Copier
955 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
