I have a 95 honda accord battery died put my code in to unlock radio and it doesn't work its the correct code cause i used it before. what else can i do?
? 1:51
https://www.youtube.com/watch?v=epnMePibIQA
Nov 12, 2013 - Uploaded by EpicReviewsTech
Yesterday the battery died in our Honda- and after the hassle ofreplacing it I thought all was well- until ...
? 5:27
https://www.youtube.com/watch?v=b0GNkf-BDXs
Mar 21, 2013 - Uploaded by Zawbone
Note: sometimes you can find the code sticker in the glovebox. ... trick should work for 2001 and newer Honda ...
Hello you will need to visit the dealer to retrieve the unlock code for this problem your having removal of the battery has cause this to lock.Dealer usually charges $15-$20.00 for the unlock code this is the best solution.
The code in the Glove box is just the serial number to the stereo, It is
not the unlock code itself. Call a Honda dealer and give them this
number. They should give you the code for free. They did for me.
cheers hope that helps
UnfortunatelyHONDA codes are only available from the Main Dealer or
by using a Radio Decoding Service who will connect a laptop to read the
working code inside your radio`s memory chip (EEPROM)
disconnect battery and let it set for an hour , reconnect battery, it should power up, if not check your fuses, turn radio on code should come up, using your six preset radio buttons( # 1-6) type in the code and it should reset
*** Please click the "Was this helpful? Yes" (thumbs up)! ***
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is
found on the credit card sized Anti-Theft Radio Identification Card
that comes with the vehicle at the time of purchase and is usually
found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet
BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom
about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6
buttons.(***IF your Honda doesn't have preset buttons on the radio then
hold down the top part of the 'Seek/Skip' button AND the top part of
the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that
display. These eight numbers are the SERIAL NUMBER. This is NOT your
CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to
get the unlock code. (can be found on your insurance card, driver's
side door jam, small plate on dashboard by registration and inspection
stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They
will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message
displaying you'll need to do an additional step for even the correct
unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out
if that's easier for you) for 30 seconds then reconnect it and then the
radio will say "CODE" again and you can put in your correct unlock code.
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the
Anti-Theft feature kicks in, the radio is rendered inoperable and the
screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code
(usually 5 digits) to make it operational again. You know that much by
now.
What you have is the SERIAL NUMBER. Your almost there!!! The hard part is over! Go to the bottom below for the website option or phone number option you need to get the unlock code!!!
CODE.
stickers, etc)
---Internet option:
-OR-
* REMOVING ERROR E3
now.
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
