Brother intelliFax 1860c
LED screen says install Cyan, Needed to replave black, did so , never used any color so Cyan still full, removed all cartridges and replaced still same msg.
  • 1 more comment
  • robin102030 Mar 05, 2008
    Unfortunately I had to replace all the color cartridges even though I never printed in color.
  • Anonymous Mar 26, 2008
    I have the same problem. I don't understand why I ran out of colors that I never used.
  • Micca82 Mar 26, 2008
    I cleaned it per your recommendation, but now it won't even recognize the cartridges. any help?
    thanks
  • 682 Answers
1-use alkhol with little piece of clean old clothes to clean both connection points in both cartridge and fax.in the place where you put the cartridge.
Posted on Mar 03, 2008
  • mohamed eltoni
    mohamed eltoni Mar 05, 2008
    please next time start with simpel
    thing which is cleaning and try to take a notice of the date of installation of the new one and try to use always as soon as possible because if you leave it for long time the ink may be stuck inside.
Change date and time on Brother intelliFax 1860C
just solved this issue on mine at work:
Push MENU, then 0, then 1. Then, enter your new time and date.
Source: http://www.manualowl.com/m/Brother%20International/FAX1860C/Manual/239514?page=4
Scroll to page 13 of 16
Jul 05, 2012 | Brother IntelliFax 1860C Plain Paper...
Why does my fax machine use up tje color
All ink jets mix all of the colors every time, even for black.
Feb 08, 2010 | Brother IntelliFax-1860C Plain Paper...
What is install cyan
Time to replace the blue (cyan) ink cartridge . . .
Jan 06, 2010 | Brother IntelliFax-1860C Plain Paper...
Black ink not working on Brother Intellifax 1860C
All i needed to do, after messing with it non stop, was turn it off and reboot the machine. Simple solution! Thank god!
Apr 28, 2009 | Brother IntelliFax-1860C Plain Paper...
I don't use the color printing yet the color cartridges are empty
It's all a scam. I have the same problem and I called Brother and they told me that the machine uses color ink to clean itself. It costs more to replace these color cartridges then to buy a new one, which is what I'm going to do. Buy a black and white from a different company. It's all a scam to get you to spend money on their color ink that you don't use.
Mar 25, 2009 | Brother IntelliFax 1860C Plain Paper...
Ink problem with Brother Fax 1860C
The machine detects the ink by shining a light through the rib in one edge of the ink cartridge. Apparently yellow is close enough to nothing at all, that the sensors get a little out of whack. Here's how to reset the sensors:
  1. Get a dinner plate or something to set the ink cartridges on, that won't absorb ink, and is easy to wash.
  2. Unplug the machine's power.
  3. Open the machine and remove all four inks, setting them on the plate.
  4. Close the machine.
  5. Plug in power.
  6. The machine will begin it's start-up procedure and complain about the missing inks. It will tell you to replace one specific ink first (black, I think).
  7. Follow the instructions on the display, installing one ink color at a time. When all four inks are in, it should be OK.
Use Brother inks. They have a little black floater in that rib, and some of the aftermarket inks have had a problem with the floater sticking.
There may be another problem causing this. The ink may really be low, or the sensor board may be off its mounts in the machine. But the routine above is quick & easy, and it fixes the problem more than half the time. You can't run without any of the colors, because that means air bubbles are getting into the ink tubes, and that can lead to dried ink blocking the nozzles.
This is unrelated, but when you peel the sealing tape from the bottom of the ink ctg., do it slowly. Brother has found that sometimes, when you strip the tape off too fast, a little glue remains stuck in the nozzle, blocking it. If that happens, dig the glue out carefully with a pin & it will be fine.
Nov 13, 2008 | Brother IntelliFax-1860C All-In-One InkJet...
Brother intellifax 1860c paper instlation
You can download the manual from Brother's website here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_1860C_1960C_MFC_3360C_EN_1424.PDF
Sep 10, 2008 | Brother IntelliFax 1860C Plain Paper...
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
121 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
