Boot up problems
When i boot it up i get an error message that says disk I/O error replace the disk, and then press any key
  • nabbey Mar 02, 2008
    when it boots up it says(Disk I/O error replace the disk,and then press any key. how do solve this problem. thank you
  • 32 Answers
It usually mean that your boot devise is not working. If you have it set to boot from floppy first remove the disc that is in there because it is not a setup disc. If you have it set to boot from hard drive first then the drive may have gone bad. Listen when you turn the computer on you should be able to hear the hard drive spin up. If not then the drive is dead.
Posted on Mar 02, 2008
Non system disk or disk error' 'replace and strike any key when ready' 'Media test failure Check cable' When l performed the Boot Utility test it returned an error message 'f
Sounds like a disk issue. It kind find the OS so it's then trying to PXE boot (boot from the network). Have you changed the boot order recently? or do you have a USB key connected to your server? are you able to connect to the management interface (hp ilo, dell drac) to see if you had any raid or other hardware issues?
Jan 09, 2013 | Computers & Internet
I have an emachine em250 and I am recieving an error message saying (check cable connection...!) pxe-e63 error while initializing the nic pxe-mof: exiting intel pxe rom no bootable device--insert boot disk...
This error message is generated when the processor can't detect the presence of a hard disk because either the disk is dead and it will have to be replaced or the southbridge chip on the motherboard (the one that controls the disks) has failed - both severe hardware defects.
If after replacing the hard disk you get the same message then you need a new motherboard.
May 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
Full instructions on removing and replacing the hard drive can be found here:
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Apr 12, 2011 | Acer Aspire One PC Notebook
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Feb 19, 2011 | Microsoft Computers & Internet
My computer suddenly shuts down Windows and displays a blue screen error message saying that there was a problem with my graphics driver, that it became stuck in a infinite loop caused by some ait2dvag...
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Dec 04, 2010 | ATI ALL-IN-WONDER 9600XT 128MB AGP DVI...
Blue screen problem in my computer.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system. Also this error comes when there is bed indexing unit in hard drive. You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set first boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows. Thanks for using FixYa.
Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi my pakard bell desktop keeps blue screening and i get following fault message- BCCODE 1000008e BCP1 c0000005 BCP2 B94D9C29 BCP3 BA487204 BCP4 00000000 OSVer 5_1_2600 SP 3_0 PRODUCT 256_1 can you help
Then press any key.
Then type "y"
Aug 07, 2010 | Computers & Internet
Disk I/O error Replace The disk, and press any key
Its the problem with your Hard disk. Try to boot from xp cd and install a new copy. you will get error on installing if Hard disk is damaged. then you have to replace with new one
Apr 05, 2009 | Computers & Internet
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
NTLDR is missing
Cause:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
