My tv has ghosting.also seems to have bright bloom area to left center. i had it serviceed once before, and repairman accessed menu and entered codes which cleared problem. does anyone have codes or info.
Shall we assume you have this already?
click here for user manual
I see that these are codes for the IR remote..This would be fascinating to find that the programming codes can correct a clear disfunctional video drivers issue, and perhaps even a video control board failure mode, which is precisely what's going on here.
From a further analysis,..you may find this of some interest.
It has a ghosting problem and the only way to adjust it is in the sub
menu which you cannot get to. Also the 50v500 is known to have a light
engine problem and that red glow is a sign it maybe having problems.
There is a reset a tech can do in the sub menu to correct the red but
if the reset doesn't work your looking at replacing the light engine.
In any event, I think you will need to have the convergence chips
replaced. There are two of them and they must both be replaced. They
cost around $50 each and require advanced expert soldering and
electronic skill to do. A shop usually charges around $400 for the
job.
Hello!
the url of
ivofreax10
is correct, just copy all the url and paste it to your IE address bar.
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=support_contact/remote_ir_codes/index.html&level=2§ion=support_contact&parent=remote_ir_codes&nav=left&path=jsp/hitachi/forhome/ubcg/&nId=iD
Please give the credit to ivofreax10, that his work. ok.
best regards melnavz
Http://www.hitachi.us/Apps/hitachicom/content.jsp?page=support_contact/remote_ir_codes/index.html&level=2§ion=support_contact&parent=remote_ir_codes&nav=left&path=jsp/hitachi/forhome/ubcg/&nId=iD
invalid url please resend
anyone have service codes or info to fix ghosting on hitachi ultravision 50v500
