Question about Epson Stylus CX5400 All-In-One InkJet Printer
Won't print(after changing cartridges
I changed ink cartridges ..now it won't print. If ink dried in the nozzles, is it possible to access them to clean/flush ? ( repeated head cleaning and nozzle checks do nothing but deplete the rather costly ink supply)
  • 4 more comments
  • Anonymous Mar 07, 2008
    I have tried everything and all I get is blank pages from the printer
  • lardog469 Apr 10, 2008
    "7" isn't the lucky number for Epson. Thanks for the thought/ trying.
  • Anonymous May 21, 2008
    Tried all the troubleshooting suggestions and still won't print after changing all the ink. Did all the headcleaning, usb cable checks, etc. Why would it suddenly quit printing altogether? It goes through the motions, sounds like it prints, and clean the heads, but not a drop of ink, of any color.
  • Ivypete Jun 13, 2008
    Changed the Black Cartrige now will not print any black
  • Anonymous Jun 17, 2008
    I have a CX5400 all in one printer , printer was working, I removed the cartrides and left them out for 4 weeks now that I have replace the cartridges I can't get printer to print I did try cleaning several times but nothing happen other than use up the ink. Is it possible to do cleaning without cartridges in the machine? pat
I couldnt find anything that would work on my printer so in desperation I tried the cleaning seven times...lo and behold..,success
Posted on Jun 11, 2008
Blank pages and bad print are not the same problem. Regarding costly ink, a epson printer tech told me once that the secrete to cleaning a bad print head was to run deep clean 7 times in a row and then a head test and it has worked for me several times on other printers (not an expert here, just personal experience).
Additional note, I have seen both cleaning chemicals and cleaning cartridges on the web, example, searching google for one for my printer I would search for cc-bci-6c which is for a canon cyan cleaning cartridge. Don't know if they work but in case it helps.. good luck.
Barry,
Posted on Apr 03, 2008
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer won`t print with black ink prints colourjust sends blank pages I changed the cartridge but no different
Hi Allan
BROTHER DCP-165C BLACK INK NOZZLE BLOCKAGE CLEANING
If your printer is under warranty then take it to a Brother Service Center for Print Head Maintenance.
If not and you are technically minded and/or adventurous, then you could try to clear the likely cause of this fault (potential blocked micro-nozzles on the print head) yourself.
Remove all the cartridges, wrap them in clingwrap/clingfilm and then place them (upside down) on an old newspaper to minimize accidental leakage > remove the print head (a small square, gold, patterned contact plate sitting at the back of the cartridge compartment) > immerse the print head in a solvent for 24 hours (sometimes longer). Below is a webpage showing you how to create, handle, store, use your own solvent recipe to and safely and responsibly dispose of used solvent:
http://www.ehow.com/how_6614390_homemade-solvent-clean-print-head.html
Remove and blow dry the print head until completely dry > reinstall print head > reinstall cartridges > repeat head cleaning and test print procedures again.
For the future, either with this or any other printer, please remember these tiny micro-nozzles can very easily become blocked with dried ink. You can protect against this by always using good quality ink, printing regularly to keep ink flowing through the system (including the odd unnecessary test print, if necessary), replacing empty cartridges without delay, not allowing drying air to dry ink residue in the micro-nozzles by never leaving a cartridge space empty for more than the few seconds it takes to change a cartridge, always fully prepare, unpack, unclip and unpeel the new cartridge before removing the empty one, try to avoid being distracted while changing cartridges (so easy to forget and leave a cartridge space empty and the cartridge bay open).
Please don't hesitate to ask for more help if you need it.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 02, 2011 | Brother DCP 165C Compact Color Inkjet...
It won't print.. it goes thru the whole process and makes you think its printing but when its done the page is blank.. I have the Dell AIO 964 printer and all of a sudden it will not print.. it has...
if the unit has been working properly for sometime and then suddenly stopped printing anything... you might try to perform a maintenance cleaning on your unit... this is caused by clogged nozzles which stops the printer to withdraw ink from its tank.... best way is to perform a headcleaning process for sometime.... if it still persist, reseat the ink cartridges... if it still does not work... try spraying the nozzle with wd40.... let it dry for 1 hr or 2.. if it still persist and the process is the same... im a afraid that we may need to have your printer serviced.... hope this helps you out...
have a grand day...At least we tried...:-)
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
How do i change the cartridges of hp psc 1215
1. Turn on the unit, then open the print cartridge access door by lowering the handle. -- The print carriage moves to the center of the unit.ionstorm_0.jpg
2. After the carriage stops moving, push down on the print cartridge to release it, and then toward you out of its slot.
3. Remove the new print cartridge from its packaging and, being careful to touch only the bright pink plastic tab, gently remove the plastic tape to uncover the ink nozzles.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge immediately to prevent the ink from drying in the nozzles.
4. Push the new print cartridge into the appropriate slot at a slight angle until it clicks into place.
Caution!
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
The tri-color print cartridge goes on the left and the black cartridge goes on the right.
5. Close the print cartridge access door.
May 06, 2011 | HP PSC 1215 All-In-One InkJet Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Color printing problems
check the in printer settings about printing with color, and also on the pc side make sure its not set to black and white only.
Jun 20, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Need to change dried old ink cartridge before it says it is out
press the Ink Change button then turn off the printer this will give you the Ink Changing psoition for a long time.
Sep 15, 2007 | Epson Stylus Color 740 InkJet Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
458 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
