Question about Samsung Digimax A400 Digital Camera
Low Light. Hi Well, When i keep pressing the button to take the picture it shoes " LOW LIGHT !" With A Baby Blue Background And White Letters. And It Wont Let Me Take My Picture. It Was Fine A While Ago..
  • Anonymous May 09, 2008
    low lighting
  • 593 Answers
Is the flash disabled?
Posted on Mar 02, 2008
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nov 15, 2015 | Nikon COOLPIX L100 Digital Camera
Why does my canon power shot hesitate before taking a picture
It's probably acting normal. Every camera (in one of the auto modes) must focus before it takes the image. In low light situations, or low contrast situations (white dog against a white background), many cameras have difficulty finding focus. This causes a delay before the shutter clicks. Try taking your camera out on a nice sunny day and take a pic. If there's no delay, there's your answer. If in a low light situation, click your flash on. That may help a bit to reduce the delay.
Jul 02, 2014 | Cameras
Service indicator reset
insert key into key slot and press the start stop button once WITHOUT putting your foot on the break. You should see numerous lights turn on,on the dash
weight for any warning lights to go out, in some cases, like low fuel warning light, you my need to press the BC buttonon the end of the indaca tor stalk once to remove them
press and hold the black button, on the bottom left of the speedometor, but keep holding down the button untial the next picture appers then release the button.
to cycle threw one by one all of the picture optctionsfor each service press black button once. when you arive at the SERVICE that you wish to reset press AND HOLD THE BLACK BUTTON until the text RESET?is visible under the picture then let go,finily press and hold the button again to conferm the reset.
Nov 27, 2013 | Cars & Trucks
How to take a good picture in bad lightning
You can find the manual here. They have some suggestions for shooting in low light:
  • Set scene to "NATURAL LIGHT" Capture natural light indoors, under low light, or where the fl ash can not be used.
  • or set Scene t "PARTY" Capture indoor background lighting under low-light conditions.
Use a tripod if available, or brace the camera against a wall, table, or other fixed object when taking pictures to reduce blurriness.
If you don't have an object to brace the camera against, use these techniques to reduce camera shake. Press the camera button instead of jabbing at it.
Search the internet for "low light photography" for more tips. The PARTY and NATURAL LIGHT settings on your camera should boost the ISO on your camera.
Do some test shots before hand in low light situations to see what works best.
Feb 11, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
The background cycles between dark with white letters and bight with dark letters, any idea on how to stop it from cycling and stay on dark background with white letters?
you need to press either the #5 or #6 preset button while the deck is in standby mode. putting the deck in standby mode should tell you which button to press.
Feb 14, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
Hi, I love my Avent SCD510 monitor, but it started acting up today. In the past, when the parent monitor was on, I could hear every move my daughter made. I could also tell that it was on by the white...
Hi there, I had the same problem. My baby monitor used to work fine, and then all of a sudden it wasn't picking up my baby's cries. I used to be able to hear the static in the background, but I couldn't even hear that anymore.If I pressed the "sensitivity" button on the side of the parent unit, I could hear the static and my baby, but after a minute it would shut off. Very frustrating!
It turns out that somehow the sensitivity had been set to low. (Maybe this had something to do with the time I let my baby play with it...) I turned the sensitivity back up to high and it worked fine.
To set the sensitivity, press and hold the sensitivity button (located on the side of the unit) for about one second. There will be a number of blue lights that light up on the front -- the more lights that light up the higher the sensitivity is. (Mine was set at 2 out of 5, not very sensitive.) While the lights are on, press the + button (located on the face of the unit) to increase the sensitivity (or press the - button to decrease it, but that is probably not what you want to do if you are reading this post.) Press + until all 5 blue lights are on, and you'll be at max sensitivity. (You can adjust it later if this is too sensitive, once you find out of this fixes your problem.)
After a minute, your baby monitor will set itself to the sensitivity level that you set. So if the sensitivity level is really low, the monitor will seem to turn "off" after a minute. If it is high, you should still hear some static.
Hope this answer helps someone! I am really glad I don't have to take this unit back, I like it.
Nov 02, 2010 | Philips Avent® Scd510 Dect Baby Monitor
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
My Nikon p80 has difficulty focusing in low light. Also, the white balance is difficult to control and most low light photos are too yellow.
Seems to be interesting.
For low light focusing problem here is the solution which works with any digital camera.
I have observed that P80 has a slow focusing symptom. If you are in TELE range that is lens out. Then you will be hitting this issue very frequently.
Check if you are not restricting that red light bulb from throwing the light on your subject.This light is to assist the camera to focus.
Try doing this. Illuminate the object with a small/capable torch. Sometimes AF assist lamp is not doing the job.
another solution is focus in small steps. move lens out a little half press the focus/snap button. repeat this till you get the desired frame. This somehow helps camera to focus difficult objects.
White Balance:
Nikon P80 has good white balance functionality. But if you do not get what you want you need to set the WB manually. Here is the procedure to set white balance manually.
Procedure:
You need to select the preset manual for this procedure. Keep a white colored object with you always. This should be of size of a playing card at minimum.
when you will select the manual white balance preset. it will show you the measure option. Keep your white subject in front of the lens and press measure such that the camera view is filled with that white object's view.
Now you are ready to go. Your Camera will take the pictures just right.
Sep 22, 2010 | Nikon COOLPIX P80 Digital Camera
Delay between pressing button and actual photo taken
hi
there is a lot to takin good pictures but its easy too
now when are you facing this prob during low light situations or regularly
if it is during low light then pitching up ur ISO settings say from some 80 or 100 to atleast 400 or 800 should do the trick but beware of a lil picture noise,
also u can turn on the continuous focus(CF) setting
also when you are taking a picture try to focus on the subject by pressing and holding the shutter button only halfway then once you r safisfied with the way it looks press it down all the way to take the picture this works for all photos whether in day light or during low light
if u have any further questions u can contact me on mail2pvs@gmail.com
cheers
pls rate if this was any help
Jul 03, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
Blue photos
You probably needed to reset the manual white balance. Lighting conditions can change considerably in 10 minutes at sunrise and sunset.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Samsung Digimax A400 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
