Question about Microsoft Wireless IntelliMouse Explorer
Wireless IntelliMouse Explorer 2.0 problems
Good batteries, I believe the driver is up to date but it sometimes takes several clicks to get the thing to function properly
  • Anonymous Aug 27, 2008
    I have been using this same mouse for about 3 or 4 years and now my left mouse button doesn't function all the time. I have to click it a few times and wave it around in the air before it will "work". I wonder if the button wore out, or something else is wrong, but the right button and the scroll button function fine. I did replace the batteries but that hasn't helped.
    Maybe it's time to replace this poor ole mouse and put him to rest...
    President:
  • 8,637 Answers
Make sure the batteries are good and try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
I have a Microsoft Wireless Intellimouse Explorer CE01220 PIN X08-70399 P/D 55083-576-0915355-0 I need the download manual and software user's guide. Please help!
Hi Ken,
You can download the software of your mouse from this link. You should select "Wireless Intellimouse Explorer", and your operating system to find the compatible driver and software. You can see the the help file there.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Jun 03, 2010 | Microsoft Wireless IntelliMouse Explorer
MS Intellimouse Explorer 2.0 scroll wheel only scrolls down
There are number of reasons and solutions why your mouse isn't working properly. No.1. Resynchronize your mouse to the Pc. It's best to use the reset button for resynchronization. No. 2. Change the Port (Usb port). Sometimes even the small problem with the port created this problem. No.3. Replace the battery. If you are sure about the battery is Live, you can try with another make eg. Sony to Everydy. No.4. Interfaces Problem. Make sure that no electronic items, metal box, Speaker, etc doesn't obstruct the connection. No.5. Driver Update. Update the driver to the latest version. You must update from the particular website. If you are using Microsoft product, you must update the driver from the Microsoft's website. No.6. Different System. Try out the device on several devices not only one. If you still have difficulty, you can visit this site for more details. http://support.microsoft.com/kb/838398 Good luck
Apr 29, 2010 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless IntelliMouse Explorer 2.0 - low battery pop up
I would disregard the pop up as in most cases the batteries are still good. I'd use the mouse till it stopped functioning. Why it does that I haven't figured out yet. I beleive a value has to be changed in the Registry. If I figure it out I will let you know.
Bud
Jan 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Mouse scroll wheel doesn't work properly
have you tried clicking on the bar that moves the page left to right and then tried using the scroll wheel?
Sep 19, 2008 | Microsoft Wireless IntelliMouse Explorer
Couldn't find the answer to the right click mouse button not working.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Sep 16, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse pointer has disappeared
Recalibrate your mouse and transmitter by pressing the button on the transmitter as well as the mouse. Make sure there in a range no more than 30 ft of each other.
Aug 11, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless intellimouse explorer 2 Wheel button
It appears to to be a faulty wheel button, when I assign one of the other buttons it works OK.
Thanks Ralph
Feb 26, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless Intellimouse Explorer 2.0 problem
DEAR, Once again install fresh driver of your mouse
Sep 25, 2007 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless IntelliMouse Explorer Logo
263 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
