Question about Refrigerators
Water leak where hose meets refrigerator connector
We had to turn ice maker off to stop water from leaking at connection
  • 7 more comments
  • Marie T Mar 02, 2008
    The refrigerator is a Kenmore bottom freezer Model 795-75002401. The little white hose on the back of the refrigerator where the water comes from the supply connector line to the ice maker comes out of the connector tube. Water is not getting into the ice maker and no ice is being made, even when I reconnected this tube.
  • Marie T Mar 03, 2008
    Thanks. I'll try this.
  • Marie T Mar 06, 2008
    Thanks for trying but I don't know how to get the inlet tube out to defrost it. Repairman coming today.
  • madu1 Aug 02, 2008
    bottom of freezer section leak gets frozen.and some times water comes out! s/s GE Profile TPX24PR
  • Anonymous Aug 05, 2008
    Maytag, water all over the floor when I checked behind the refrig, I could see water pouring out around the gasket.
  • Anonymous Aug 27, 2008
    Mu subzero is leaking right by the hose as well. Water is collecting inside under the fruit drawer and outside puddles on the floor. I'll be turning off the ice maker. I'm wondering if there is anything else I should be looking for before I get a qualilty repair out.
  • Anonymous Aug 28, 2008
    hose leaking at water valve that feeds ice maker. new just bought put on whirlpool refrigerator. help
  • Anonymous Sep 12, 2008
    I have the same issue, water leak
  • Ron Coons
    Ron Coons May 11, 2010
    who makes unit and what the model??? where was it leaking from exactly?
First insure that tube is not frozen at dump point into ice maker. To prevent hose from separating from connection tube through back of freezer-apply small amount of glue (krazy glue etc.0 to tube and re insert into connector. Solved my problem.
Posted on Feb 02, 2010
Has anyone heard of the product Flood Detective. It's a water leak detection sensor/alarm and will at least alarm you before mold and leaks get out of control? Have one installed under my sink, water heater and refrig. Find them at www.leakalarm.com.
Hope this helps!
Steph
Posted on May 23, 2008
    President:
  • Refrigerators Master
  • 2,651 Answers
Thinkin the line is frozen within the freezer wall leading to ice maker. the white hose from bottom of refrig to top freezer ice maker inlet os where leak is?? try removing it and blowthough the line onto freezer section, if cloged(of frozen) the inlet tube can be removed adn thawed out
Posted on Mar 03, 2008
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Posted on Mar 02, 2008
Ge GSL25JFTA is leaking water on the floor from the front of the unit
Turn off the water supply to the ice maker. If it stops the leak, look for a leaky O ring on the filter. There is a plastic hose that runs out of the front of the refrigerator and goes to the freezer door for the water dispenser. It has a connector near the freezer door lower hinge so the door can be removed easily. That connector can leak as well. There is a condensate pan under the refrigerator that may be over flowing too.
Mar 21, 2015 | GE Refrigerators
Samsung refrigerator problems
Well you will have to trace out the water line and see where leak is coming from .If you disconnect everything and pull on that water hose it would come out BUT do it slowly
Dec 22, 2017 | Samsung Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
We have a puttering noise every 2 months or so, and I have to defrost the freezer to get the ice off the fan. We have had the icemaker replaced under warranty, but it didn't stop the problem, it
it is possible there is a bit of splashing and drops of water fall on the light cover during fillup of the ice maker make sure the hose that leads in the ice maker is positioned correctly to prevent water splashes. Or lower the water pressure to the hose of the ice maker. Good luck.
Jan 05, 2012 | LG LSC26905TT Side by Side Refrigerator
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i turn off the ice maker on a ge profile. thereis a bad leak from the hose in the back. can i just turn off the ice maker to stop the water flow?
You can lift the lever in the ice hopper to turn off the unit, or simply unplug the electrical connection to the ice maker inside the fridge. If your leak is in the line between the house supply line and the valve on the icemaker, turning it off will not solve your troubles. If that is the case, you can turn off the supply line valve.
Jun 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
WATER LEAK FROM BOTTOM
the ice maker is a common fault on those appliances expensive to replace but quite easly done with regard to the leak eithr the drainage tray is blocked or one of the water feed hose is disconnected or leaking call an engineer
Nov 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Sep 13, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
2,766 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
