Question about E-Machines eMachines Monitor E15T4
E-machine monitor e-machine blue on button turns yellow and no picture
  • Anonymous Apr 14, 2008
    Must turn off and turn on monitor to wake it up from standby.
  • materialgrll Jul 26, 2008
    my on button is green when turned on, and the monitor is on.  The picture shows for one split second, then disappears.  This happens every time I turn it off and back on.
  • 3 Answers
I open the monitor and disconnect first one lamp connector and then turn on
Posted on Jul 01, 2008
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
When I turn on computer, the blue light comes on and the computer makes sounds as if it is starting and the monitor light is yellow. If I turn the monitor off and then back on, the screen says something...
No input usually indicates the machine is having trouble getting a video signal from the monitor. Check and make sure the monitor cable is connected properly. If you have another monitor also test the machine with another monitor.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Monitor blue light comes on shows emachines logo and color bars then monitor turns off and light turns yellow
your monitor is beleiving it is not receiving any signal from your pc. 1 make sure your cables are secure. 2 make sure your pc is on. 3 borrow a monitor from a freind to see if your pc is sending the signal out, if the borrowewed monitor is showing a picture, hook yours back up. 4 if still not picture your mpcb or video pcb in the monitor is bad.
Oct 28, 2009 | E-Machines eMachines Monitor E15T4
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My Sony Moniter suddenly turned to a bright yellow
If the display looks normal other than being yellow, it's missing blue.
This may be because of a bad cable. Sometimes the wires inside break from flexing. Try wiggling the cable (as mikeslab suggested) at the end where it connects to the computer. Also check the plug for bent pins.
It's more likely the monitor has lost blue due to solder connections to the blue output transistor or transistor failure, or that the picture tube itself has gone bad and the blue gun has quit. Tube failure is pretty rare. I've seen many cases of bad connections and transistors, though.
If the cable and plug aren't the cause, you can have a service shop check the monitor and give a repair estimate. But if this is a 17- or 19-inch monitor, you might just want to replace it. New LCD's are $150 or less. To repair yours would be around half that cost already, possibly more depending on labor and parts costs.
Apr 24, 2009 | Sony Computers & Internet
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
My monitor turns yellow
Computer monitors get separate red, green and blue video signals from the computer, and if you lose the blue the result is a yellow picture. This can be caused by video card failure in the computer (very unlikely), a bad cable (fairly common), or trouble in the monitor (which is most likely what you have).
The usual problem with monitors is bad solder connections to the red, green and blue output devices. These are usually three separate transistors, but sometimes an integrated circuit that puts all three in one package is used. These outputs get pretty hot, and the heat can cause the connections on the circuit board to crack. Resoldering them usually fixes the trouble. (Sometimes the part actually fails, but bad connections are more common.)
The parts are normally in one of two places. Most commonly they are on the small circuit board you'll find right at the neck of the picture tube. Some monitors have them on the main circuit board. They may be mounted to metal heat sinks to help keep them cool. If you can identify them and resolder the connections, you'll probably get your normal picture back.
Sep 22, 2008 | HP mx705 17" CRT Monitor
E-Machines eMachines Monitor E15T4 Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
