Question about Xerox Phaser 8500N Printer
My 8500N prints reams of code instead of the jpg sent to print
I am printing from Preview. the first file will print ok, if i load the que with more than one file at a time it prints the code instead of the image
    President:
  • 2,072 Answers
First off and I am sure you have tried this, but power of then power up your printer. Just to allow it to reload the software internally.
The other thing is to change drivers. That is what is generating the code.
You can go to Xerox.com there is a varity of drivers to try. Sometimes a PS and PCL driver will intrepert differently and print code like that.
Not sure preview is where the problem is. But I am assuming it prints fine in other applications.
There is also a firmware update on the xerox.com site, you can upload the newest printer software there. Or at least start out with a clean version on your printers operating software.
I strongly suspect a driver change will help.
Posted on Mar 02, 2008
Why does some txt print when using ctrl shift print to print a document or email and some lines do not print at all?
There are two way email e-print.
A> Open email and select print area and see preview, if preview ok then you given print. If not ok then go to printer setting option and set printer paper or text. Then see print preview if ok then given print.
B> Second option is copy email print job any doc file or then print select and command given. But print before also check it print preview.
If any issue create i share a print related problems link please visit and read it. I hope solved your issues.
Source..ePrint Job Did Not Print
Thanks,
HP Phone Number
Jun 23, 2014 | HP Officejet Pro 8600 e-All-in-One Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Nef images instead of jpegs
Not sure I see a question as printed but I will assume you'd like some info on NEF versus JPG files. Simply put, if you're shooting simple pictures and just want to download, email, etc. then JPG will be fine. NEF produces an electronic equivalent negative meant to simulate a film negative. This gives you latitude to touch up the negative before printing and provides the most adjustment range and options. Many programs cannot use the NEF format so it will mean deciding how you want to save the pictures. Of course, they take up more file space as NEF - 10-12 MB instead of 6MB or so for big JPG files. I shoot all my pictures in NEF then convert them to JPG for normal use and printing. I burn the NEF to a CD or DVD for archive and future needs. All that takes up more space of course.
Nov 06, 2010 | Nikon Cameras
How to print a page from a website
Please follow the steps to Print a web page using the Internet Explorer or Mozilla web browser.
>Please click on File, Print or press Ctrl+P key and then select the Printer( HP Officejet 5610), select the page range and click OK to print the web page contents.
>You can also preview the web page you're trying to print and then print it (File-->Print Preview).
Good Luck!!!
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
I click print but nothing happens.
Try just copying something on the machine. Does it print? If so, its a computer problem try setting up your prunter software again
Apr 23, 2009 | Brother MFC 420CN All-In-One InkJet...
Cannot load JPG files in Print Shop 23
is your programme a text only prog? are u frying to load graphics using a text transfer button? try the insert button instead of the import button then choose picture.
Apr 16, 2009 | Encore The Print Shop 23 Deluxe Full...
Canon MX310 - print is gray instead black. How to fix it.
I wish someone would REALLY solve this, but I've found two (time-consuming!) workarounds:
1) Despite using plain paper, tell it you're using "Matte Photo Paper" (this is necessary in order to...) then set the print quality to the next-to-highest level (default is middle of five quality levels). The doc will print in black as it should, not grey.
2) Instead of the above, use the printer dialogue option to print to a PDF file; then open the pdf and print it. It will print in black, not grey!
WHY WHY WHY WHY WHY?????????!!!!!!!!!!!!!!!!!
Dec 31, 2008 | Canon PIXMA MX310 All-In-One Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
Having trouble printing a document file in word
Check page setup and ensure page size for document same as page size for printer.
Check printer not set to only print current page.
Feb 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Xerox Phaser 8500N Printer Logo
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
