Question about Ricoh Caplio R4 Digital Camera
Ricoh r6 lens wont shut can hear it grinding no lcd
F.U.B.A.R.
Posted on Mar 08, 2009
Focus on Ricoh R6
Could be that the electrical connector on the autofocus has come off. This is a job for a repairer.
Mar 21, 2012 | Ricoh Caplio R6 Digital Camera
Dear Sir, I accidentally dropped my Ricoh Caplio R6, 4 days ago, on concrete pavement while taking photos. The zoom lens was stuck open and cannot retract. Please give advise to me where to repair this...
Professional repair will likely cost more than the value of the camera. But here are some things that you might try yourself.Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Oct 23, 2011 | Ricoh Caplio R6 Digital Camera
I have a EX-S600 Casio. When I turn it on the lens pops out, I get 3 audible beeps, hear some grinding and then the lens retracts and the camera shuts off, it all takes about about 6 to 7 seconds. I've...
If you hear a grinding then it's toast. Any issue with the mechanism would cost more to have repaired than replaced. This usually happens as a result of the lens being bumped while open or opened in a bag. Or, a contaminate such as sand inside the body of the camera.
Mar 28, 2011 | Casio Exilim EX-S600 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
Camera lens stuck open. Cannot power up.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Jul 03, 2010 | Ricoh Caplio R6 Digital Camera
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
Dark circular spot on Ricoh R6 screen and images
There is a spec of dirt that made it inside the camera and has landed itself on your image sensor.
If you take a picture and the image has a spot on it, it could be the screen. If you transfer it to your computer and the spot is in the same spot, its something on the image sensor. You would have to send it out for cleaning, and a new camera would be cheaper.
Mar 30, 2009 | Ricoh Caplio R6 Digital Camera
Camera lens won't close says error 00000
This is a known problem, they wont easily admit it but we had 2 R6's and an R7 with the exact same issue. If you look on ricoh site they had a firmware patch for the R6 to try and fix this issue but it dis not work.
Lady at ricoh UK admitted there is a design fault with the Ricoh R6 and R7 and she sent me an R8 which has a whole new redesigned mechanism.
Dont let them sell you useless kit, get a replacement free of charge or complain.
Jun 20, 2008 | Ricoh Caplio R7 Digital Camera
Ricoh caplio digital camera
Stewin
Problem of lens not retracting fixed in one day by general camera serviceman. He said a part was broken and has fixed it without access to genuine parts.
Mar 21, 2008 | Ricoh Caplio R6 Digital Camera
Replacement lcd screen
look through ricoh's website, they have a company that they do service and support through, I just ordered an lcd for my r6
Mar 15, 2008 | Ricoh Caplio R6 Digital Camera
Ricoh Caplio R4 Digital Camera Logo
153 people viewed this question
Top Ricoh Cameras Experts
Marvin
Marvin
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
