Question about Teac R-H300 Dual Cassette Deck
No Power I purchased this deck about 7 years ago and have played it for a total of about 5 minutes. I went to use it today and it doesn't power up. I checked the fuse inside and it is good.
  • hkancyr Mar 16, 2008
    I used an ohm meter. I tried several different outlets. I opened up the unit and went in as far as I felt comfortable going in, I couldn't find any more fuses. Unfortunately it does sound like a power supply, I guess I'll have to send it in for repair. Thanks.
    Scholar:
  • 49 Answers
How do you knoe it's good? Does it LOOK good, or did you test it with an ohmmeter? Sometimes - particularly when the get old a fuse can LOOK good, but be bad.
Other possibilities - power cord, plug or outlet bad (is the outlet the un it's plugged into on a switch? Are there other WORKING appliances plugged into the same outlet?)
Sometimes there are other fuses not readily visable - INSIDE the unit.
Last - and worst power supply in the unit simply quit. And that a big repair.
Let me know what you find.
Posted on Mar 16, 2008
2003 Saturn Ion won't start in the cold weather
First of all your service light came on so give it a service then have the service light reset then check the thermastac, water levels and the choke is working properly and all the elecric working parts are good
Jul 05, 2017 | 2003 Saturn ION
I have an Aiwa X-88H stereo system I purchased in 1989 It went into storage in 1999 Powered up today for first time since then and both casette decks do not work
It's been 8 years since you've used the system, so over time, the belts may have dry-rotted. Most likely, it's the belts. You can see if you can get them replaced, or, if you know what you're doing, you can replace them yourself.
Oct 01, 2012 | Aiwa Audio Players & Recorders
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
Security feature problem on car cd deck
i have never seen a jvc that required a security code. it is possible that you may have a bad power or ground connection if lights are blinking off and on. sometimes when a deck has been sitting for a long time capacitors may dry out.
Apr 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
Pioneer VSX-9700S Audio/Video Receiver powers on then shuts off
The Pioneer 9700s is a very good sounding unit, if you are talking in home threater space, but your problem sound like the power amplifer section is giving out too HIGH DC voltage therefore ripping the protection circuit. In these newer home threater ammplifers, there are not dc offset voltage adjustment on the circuit brd. All is done by negative feed back. Sorry you ar eout of luck I don,t hinkit is worth fixing. They are not as well make as the older Sa7500, and Sa9800 amplifers of old. There is a good chance that aftera few month something else will go on them. That is why they are so cheap on Ebay, these thraeter receivers.
Apr 18, 2009 | Pioneer Audio Players & Recorders
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Power
I had a similar problem with a Shop Vac. The solution was to disassemble the power switch and polish the metal electrical contacts to remove any oxidation caused from humidity. Tedious and time consuming but effective.
Dec 13, 2007 | Craftsman 17026 Wet/Dry Vacuum
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Teac R-H300 Dual Cassette Deck Logo
97 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
