Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark X74-75 Problems
The status light is blinking. Also I'm trying to see how many things is in the queded.And at one point it was having a communication problem.
  • Anonymous Mar 13, 2008
    I can print online but unable to copy and scan using Lexmark 75 icon on desktop.My Lexmark solution center states states cannot communicate with printer.Its wotked great for 4 yrs and then this.I have unplugged all cable 6 times.Pls help.Thanking You In Advance,.
    Howard
    417-581-7717
  • campitos_178 Dec 02, 2008
    the status light keeps on blinking but there seems to not be any connection between the computer and the printer
Como colocar el papel de fax
Posted on Mar 04, 2008
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
Lexmark 6500 orange blinking light
Blinking orange on the WiFi light means one of the following:
  • The printer is out of the range of the wireless access point (wireless router)
  • The printer is trying to communicate with the wireless access point but the wireless access point is turned off or not working properly.
  • Either the configured printer of the wireless access point has been turned off and back on, and the printer is trying to establish communications with the network.
  • The wireless settings of the printer may no longer be valid.
You may refer to these articles from the Lexmark website to fix the problem:- Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Jan 24, 2012 | Lexmark Z2420 Printer
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
Have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Jul 16, 2010 | Lexmark E260dn Laser Printer
Status light flashing -- no communication with the printer
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
May 26, 2009 | Lexmark X75 MF All-In-One InkJet Printer
GREEN LIGHT KEEPS BLINKING PRINTER DON'T PRINT
hi rudy, thank you for using fixya.
when you said a green light was blinking was it the power light or another green light on the printer?
i strongly suggest that you refer to these links to have it fixed if it is a blinking power light.
For instructions on how to clean the ink cartridges: http://www.fixyourownprinter.com/forums/printer/26642.
For a diagnostic procedure: http://www.annoyances.org/exec/forum/winxp/1073811565
For instructions on how to un-install and re-install the print drivers and other Lexmark software problems: http://www.techspot.com/vb/archive/index/t-10556.html
otherwise, we are looking forward to your reply.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
My Power button is flashing and the status.
Well the issue might be with the cartridges or the printer itself.however, please remove the cartridges from the printer and check whether the light is blinking. If the light is blinking then the issue may be with printer hardware. If the light does not blink, then try installing one cartridge at a time and check on which cartridge instaling does the light blink.
Apr 03, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 printer/scanner
This printer/scanner, hooks up to the computer via USB. The USB cable goes into the back of the printer on the right hand side (opposite side from the power supply). The status blinking could indicate either; 1. No paper 2. No or very little, ink.
May 25, 2008 | Lexmark X75 MF All-In-One InkJet Printer
Blinking light -no connection
reinstall your printer drivers
Sep 02, 2007 | Lexmark Z600 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
