Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung hln5065 picture issue
I am having issues getting the lamp to light, which I believe to be related to the ballast. The TV tries to spark for a minute or two before giving up and plashing all three lights on the front.
  • indyvatorman Apr 16, 2008
    i had this same problem, and if you unplugged it and let is set for 10 minutes or so it would work, now it wont even do that, but it does cycle thorugh the volume and the lights on front light
Also check the cover switch, If that ok look at the color wheel
and make sure you fans are working
Posted on Mar 31, 2008
  • Samsung Master
  • 8,617 Answers
If all 3 lights are blinking on Samsung DLP it means your lamp is burnt out or has issues. The manual says replace the lamp when all 3 lights are blinking. If you can hear the arc from the ballast the lamp should light if the lamp is operational.A new lamp should solve your problem.
Posted on Mar 01, 2008
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Issues with replacing Ballast
The flash code indicates that the lamp cover is not installed correctly. There are safety switches built into the housing that require the cover be installed correctly for the set to work. If the cover is actually in place correctly, there may be a broken switch. Check for this and update this if you can not resolve the problem.
Dan
May 08, 2008 | Samsung HLN5065W 50" Rear Projection...
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
My tv turns off
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
My projection tv
Nov 23, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung 46" DLP
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
No sound or picture
Sep 29, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
487 people viewed this question
Henry  Thomas
Henry Thomas
