Question about HP Pavilion ze2000 Notebook
Laptop Problem When i power on the laptop it beeps twice then shows a screen Press to resume, to setup but my keyboard doesnt respond to the buttons i press HELP PLS!
  • 5 more comments
  • fatalnix Aug 27, 2008
    I have this problem with the pavilon ze2000, Looking for ways to fix it, I managed top plug a usb keyboard in however that neither does work, possibly because usb bios support is not enabled? Unsure. But I'm getting a little angry at this myself...
    I've been wanting to reformat it and put a real Operating system like UNIx based, etc, but I cant even get this ze2000 to boot at all. As for me, there are two beeps and it shows f2 to setup and f1 to resume. but crashes right there. When I seem to leave it off for a few days and try again itt managed to get to some blinking cursor ( an underscore), but nothing else. There has to be a way to fix this problem, without returning it, as I've already had the thing apart many times, as I have many laptops in the past.
  • barbarahall Aug 28, 2008
    Mine is doing the same , It will beep 2 times and then it says press f1 or f2 to continue but the keyboard dont work. What can i do????????
  • barnesj Sep 12, 2008
    I am having the same problem....HP tech support was no help. Can someone tell me what they ended up doing to fix the problem? HP Pavilion ze 2000 pc notebook two beeps blank screen f1 to resume f2 to setup but nothing happens when you press the keys not booting...thanks Julie
  • Anonymous Jan 31, 2009
    I'm having the same issue. When the laptop powers on I get the HP start up screen and then 2 beeps and screen that says 'Press to resume, o Setup, but nothing works. I've tried at boot up to boot into safe mode. It won't recognize any key press. There seems to be a screen that flashes quickly between the start up screen and the Press screen, but it flashes too fast to read it.
    I've tried to boot from CD, it does exaclty the same thing.
  • DasKuken Feb 01, 2009
    Hi Guys,
    I Have the same problem seems to be a problem with the Bios, I remember last time it worked, there was an update from HP waiting for my laptop to reboot, I did it and then my lap died.
    Do you know how to fix it, or did you found a way to fix it?
    I don't know what HP support can do, but I don't trust them at all.
  • Anonymous Apr 01, 2009
    Same exact thing, no warranty. I'm screwed. fck my life
  • Anonymous May 06, 2009
    mine is doing exactly the same thing!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
If you are still in warranty, or even not, HP support is very helpful, moreso than most. If you have no computer access, call:
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products
Posted on Mar 02, 2008
I m having problem concerned to ethernet realteck...if i keep cable off laptop works excellent and normal all function ....as soon as i keep cable in socket of ethernet .....screen become blue and say memory dump.and other msg and keep on restarting ...pls send me solution on hsp5in@gmail.com as soon as u can
Posted on Mar 16, 2008
HP Pavilion ze2308wm laptop won't boot up
It could be the memory modules (RAM). Get the information from those RAM sticks (manufacturer) and replace them with new ones to see if that solves the issue, if not then maybe the hard drive, and if it's neither of those, I hate to say it, but it sounds like a bad motherboard :(
Mar 14, 2010 | HP Pavilion ze2000 Notebook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
Mar 23, 2009 | Toshiba Tecra A3 Notebook
Cant See Post
The 2 beeps are an error code. It can mean a couple of things; 1. Bad or improperly seated RAM; or 2. Bad or improperly seated video card. The F2 option will take you into bios setup. But I would try the video card option first as it is the usual culprit in this situation. Hope this helps & please rate this solution fixya. Thanks.
Feb 06, 2009 | Compaq Presario M2000 Notebook
Compaq laptop/no boot up
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | HP Compaq Presario V2000 Notebook
Laptop will not respond
It sounds to me that you may have an issue with the keyboard itself, as most BIOS will stop on a keyboard error unless told otherwise. But, this could be a malfunctioning keyboard, or a disconnected keyboard. 1 way to test either is to press the caps lock, num lock or scroll lock keys and verifying the corresponding light turns on and off with the button presses. If they do not respond, it's likely the keyboard has become disconnected internally. Other issues may also cause this to happen, but they are harder to test for. If it does respond, then it's more likely to be a keyboard failure, and a replacement of the keyboard may be required.
Hope this helps!
-Backu
Jan 16, 2008 | HP Pavilion ze2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion ze2000 Notebook Logo
722 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
