LCD TV not working
When I turn on the set, I get a picture and sound for about 2 seconds and then it switches off into standby.
DUAL TV set model DLCD2602
  • 2 more comments
  • johncam1967 May 24, 2008
  • Tattoni1957 May 25, 2008
    I have a Flat screen TV (Dual DLCD2602). When switched on the picture/sound now only works briefly (1/2 secs) after which it has started to revert itself back into standby mode.
  • johna111 May 31, 2008
    i have a dual dlsc2602 lcd tv. when turned on green light comes on for 1-2 seconds then reverts back to stand buy. any ideas? any circuit diagrams or set the same as another chasis? and data at all.
  • terrykaybrit Jan 19, 2009
    Have a DLCD2602 switches on for 2 seconds then goes to stanby
Im lokking for screen dlcd dual 2602
Posted on Apr 13, 2010
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
V is not working. when we press standby button to switch on 1 second on and have sound not have picture and go to off
It sounds to be a main power regulator board fault. Chekc and replace it. To get some details, Pull up older posts.
Dec 08, 2013 | Sony KLV32S550A 32 LCD TV
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
I see so many here with no sound/nopicture issues:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_30_2012_3_13_49_pm.jpg
Apr 27, 2012 | Televison & Video
No picture on my lcd tv, sound but just a black screen, no warning of something wrong, just turned on tv one eve and no pic.
1 Check the antenna/cable connection 2 Connect the TV to the AC power outlet and press power button on the TV 3 When the indicator light(standby) lights up in red, press the on/off switch on the remote. 4 If this does not work, reset all settings to factory settings by going through menu and selecting settings
Jan 14, 2010 | Televison & Video
LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Nov 21, 2009 | LG 19LH20 19 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Televison & Video Logo
257 people viewed this question
Top Televison & Video Experts
