Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Getting off of channel three
Just moved into new house and got discnetwork. my sony is tv #2. they told me i would have to select eithor channel 60 or 113. i can't get the tv off of channel three. model kv27fs120, serial #
  • 185 Answers
You can download a copy of the manual >HERE<
Wait for the manual to fully load and you can then browse through the pages.
It shows how to set up the tv channels on Page 17
Hope this helps you out :-)
Posted on Mar 01, 2008
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
How do you switch from cable to antenna?
go into the menu-there will be a section where you can select tuner function-select eithor cable or ant then autoprogram tv
Sep 07, 2009 | Durabrand DWT1304 13" TV
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
Sony TV Trinitron
I think you have K5 model, if so, replace the all the control switches under the tube, inside the flap.There are three columns of two switches.
Nov 09, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
