Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
How do you bypass sensors for craftsman garage door opener
The sensors won't align - one is blinking green and the other is steady amber - the wall pad if held down will close the door, but you cannot just tap it or the remotes won't close it at all. We were hoping to just disconnect the wires to the sensors, but it still won't close all the way unless we hold the wall device until the door is completely shut. Any suggestions would be appreciated.
  • my kids Apr 26, 2008
    I dont want to use the sensors at all-how can I by pass them? Thanks
  • 3 Answers
The sensors are safety features so the door won't close on someone. When you hold the wall button down it's over riding the sensors, therefore it works when you hold down the button but will not work when you tap it or use the remote. Line up the photo cells so they stop blinking. If they're blinking they think something is in the way...hence not closing. If you can't get them to line up and stop blinking one may be defective. Contact the manufacturer and see if you can purchase a replacement set. They usually aren't too expensive, maybe $20/$40.
Posted on Apr 01, 2008
  • 85 Answers
So, are you saying that you think the sensors are defective and they aren't detecting each other? If so, you should probably let craftsman know and ask them for a replacement.
Posted on Mar 16, 2008
How do I fix my garage door opener? May have moved sensors. Door will not open or close. Tried to align the sensors but don't know if they are aligned or not. When I push the wall button I hear 2 clic
on mine i have one red one green just the same keep trying to adjust the blinker or both till it is solid color check wires on back of it also.
Jan 17, 2015 | Building Materials
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I thought my sensors were not working, so I bought 2 new ones. I hooked them up, and the amber one glows, but the green one does not. I put the two sensors face to face to see if I could get the green one...
The sensors must be connected correctly. The solid white wires from each sensor go to terminal #2 on the motor unit and the white wires with the black stripe go to terminal #3.
Nov 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My red light sensor is blinking constantly and the green light sensor is steady. I grab hold of the red light sensor and squeeze and the light goes solid and I am able to close the garage door. when i let...
It sounds like there might be a loose wire connection on the inside of the sensor. You could also be moving the position of the sensor slightly into alignment when you squeeze the sensor. You will need to disconnect the wires for the sensor on the garage door opener or disconnect the power. Then use a flatblade screw driver and carefully seperate the sensor case. Check for any loose connections on the wiring(you might need to re-solder the wire to the sensor eye). It sounds like a loose wire connection to me.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need help with craftsman 315 opener. this is a new install and the safety sensors are not working properly. even when they are not aligned properly, both the green and amber lites are lit solid,should...
Check to make sure you have them properly connected at the motor. The solid white wire from each sensor goes to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My light on my craftsman garage door opener won't turn on
Unplug the unit from the power and take a small screwdriver and lift the center contact in the light sockets just a bit. This usually fixes the problem if you haven't had electrical surges or lightning.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hod do I align the sensor lights?
Your problem is not with the safety eyes. You have a stripped gear inside the opener. Take off the cover and you will have white shavings in the bottom of the cover. You can repair this with a liftmaster gear and sprocket kit.
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only works partly
some thing blocking sensor or laser is not in proper alinement
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
2,363 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
