Kenmore 110.82984120 Washer fills and washes but wont spin at end
Washer didnt spin after it drained. It just makes a swishing sound when I close the top and turn back to spin. I washed a big load of heavy cotten garmets, and think I broke something. I looked underneath, and noticed a torn rubber squishy belt. Cant find it in the partsonline or anywhere! Can I fix and get parts myself?
  • kimfit Mar 02, 2008
    Ok, guess this is the replacement for the original. Looks nothing like what I fell off the motor when I looked under the machine. Guess I need to find a repair manuel or is this something I can do myself?
    Problem Solver:
  • 6 Answers
You need a motor coupler part# 285753a. It's the plastic and rubber connector between the motor and transmission..
Posted on Mar 02, 2008
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753. mounts directly to the motor shaft and connects to the transmission, when you ge the part itll be apparrent
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Washer makes noise but, wont drain or spin
Check the lid switch (the part that gets pushed down when you close the lid). Try pushing it down with something. If you do not hear it make a CLICK sound, then it needs to be replaced.
Note: ALWAYS unplug appliances before attempting to make any repairs!!
Mar 14, 2009 | Kenmore Washing Machines
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
