Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint washer I have a hotpoint washer, that will not spin. Nor can you get water to come in. The motor hums, there is nothing wrong with the belt. Its like it wont "click" into the spin cycle. Any Ideas?
    Novelist:
  • 131 Answers
Your machine has multiple issues. First, the obvious: are the water lines turned on? When you try to fill it with water, can you hear the water valve humming? Try different temperatures, too. If it lets one temp in, but not the other, you need a water valve. If it doesn't hum at all, you could have a problem with the pressure switch or the timer.
The motor humming is the issue that worries me. Try removing the belt from the motor pulley. If the motor turns now, it's a transmission problem. If it won't agitate (you'll have to satisfy the pressure switch first) or spin at all, your transmission could be locked up. I've had limited success by pulling on the belt (hard) in both directions. This has only worked once to unjam the transmission.
Posted on Mar 12, 2008
Instructions hotpoint wml540
Check belt hasn't snapped/ come off,,,then check motor action,,,,put on spin and tap motor gently see if it helps
Jun 16, 2013 | Washing Machines
I have a Hotpoint BWM129 - it has stopped spinning - the motor hums and the belt is ok. Can anyone help?
Check the motor if this is still OK. If it is no longer spinning or running, look for the running capacitor.
Note the rating in microfarads or take this off as your
sample when you buy a replacement. Put the replacement in place, and restart. Please let us know
by e-mail and put in your vote for the solution.
Sep 26, 2009 | Hotpoint BWM12 Front Load Washer
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Makes a humming noise but then nothing
the motor is bad. it will need to be replaced or purchase a new unit ( depending on cost of repair ). Joe
Nov 18, 2008 | Hotpoint Washing Machines
Motor runs, but no spin.
You don't list model number so this will be a bit generic for Hotpoint top loader. If the motor spins but the belt is not moving: With power off, manually turn the large pulley the belt goes around, just a revolution is enough. Spin is CCW, but you may have to try CW (agitation). Now set turn the washer on spin again. This may unlock your transmission, but unfortunately is usually only a temporary solution. If the machine was manufactured prior to 1-1-06 and still under five years old, the transmission may still be covered under warranty. Check the back pages of your owner's manual. (labor would not be covered) If too old / not covered, I'd invest in a new front loading washer. The LG's are #1 rated in Consumer Reports and are direct drive (with a 7 year warranty on the motor) so there is no transmission, clutch, belt, or pulleys. You don't have to get the top of the line model, all LG's are direct drive and very good. Other front load machines, although not DD, will also use much less water than your hotpoint and spin out twice as fast or more, reducing dry time and dry cost. I know this wasn't what you really wanted to hear (bad news), so don't bother rating this "solution". (don't want my rating to go down just because I told someone bad news about there machine.)
Oct 05, 2008 | GE Hotpoint 2.7 cu. ft. Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint Ultima WT860
check your belt if not that it will be yhe bushes on the motor they might need replaced or a faulty motor
Feb 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
