Question about Symantec WinFax Pro for PC
Receive on winfax
Am able to fax but cannot receive
  • Eric Davis May 22, 2008
    I'm able to send single and multiple page faxes including scanned images from winfax pro 10.2. When receiving, it would ring and not answer, then on the next incoming fax, it would receive. Now it either rings without answering or freezes during the incoming transmission. Symantec no longer supports this discontinued product. Already tried there. The steps I've taken to attempt resolving the problem are pretty general like: deleting temp files, defrag, Norton systemworks, running spybot. No luck.
Also i have same problem. I can send faxes but during incoming calls program is answering but can not receive. I can see the phone number of sender but speed : 0 on answer window. Could someone help me?
Posted on Jun 06, 2008
You're going to have to post more information for anyone to answer this question.
Posted on Apr 24, 2008
4 Suggested Answers
JustAskMe
  • 29 Answers
SOURCE: How To Import Individual WinFAX files? .FXR and .FXD
Hi You can go to:: http://www.getafreelancer.com and post this request. I've seen it there before you wil need some third party app. Look for Project Number 138099 this will give you more info. Have a Great Day!!
Posted on May 04, 2007
SOURCE: Winfax Pro on Xp - Update to Vista - Winfax data viewer in Vista?
Try FaxTalkPro. It imports WinfaxPro phonebooks and files, and the interface is very similar to WinfaxPro. The link to the trial version is:
http://www.faxtalk.com/products/ftfcp/trial/files/trialdl.htm
Posted on Feb 12, 2009
GetFaxing
  • 143 Answers
SOURCE: cannot close controller to allow re-install of winfax pro 10.02
Control-Alt-Del and end tasks Wfxctl32.exe, wfxsvc.exe , wfxmod32 ...and faxmng32.exe
This can be any number of problems, like corrupt logs, too many entries in your default log structure,. You can check this link regarding rebuilding your logs:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=Help;CODE=01;HID=30
WinFax Tools has many fixes for WinFax that are automated.
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Posted on May 29, 2009
I have a BSNL boardband connection, can you tell me how can I configured?
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
Dec 10, 2010 | Symantec WinFax Pro 10.0 for PC
We cannot receive any faxes and get the error '
We've seen this error many times, and in most cases the problem is due to mismanagement of the send and receive logs. You probably have way too many faxes in your Receive Log (or, some corruption) You should read this
http://www.getfaxing.com/winfax/2009/08/18/organizing-your-faxes-with-the-winfax-pro-message-stores/
Mar 22, 2010 | Symantec WinFax Pro for PC
I give up. I have winfax software on this machine, but I am new at the job. Please can you help me link my fax to the winfax software? I am not able to send faxes as I think you actually have to be...
You need to setup a fax modem to be able to send and receive faxes with WinFax.
In WinFax, click on Tools, Setup.
Click on Modems & Communications Devices.
Here you can configure your fax device.
You need a fax modem, a DSL modem or a cable modem is not a fax modem.
I suggest you read this:
http://www.getfaxing.com/winfax/2009/06/25/first-time-guide-to-winfax-pro/
Jun 29, 2009 | Symantec Computers & Internet
Winfax sending and receiving
Do you have a fax modem? A "DSL" modem does not work.
Feb 19, 2009 | Symantec WinFax Pro for PC
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
Jan 02, 2009 | Symantec WinFax Pro for PC
One line two Devices
WinFax will support two modems, but I believe only one ISDN device. So, you can't use both ISDN and analog fax modem at the same time.
Nov 24, 2008 | Symantec WinFax Pro 10.0 for PC
Nov 13, 2008 | Symantec WinFax Pro for PC
Receive fax on the fax system as well as your PC
If you change the number of rings on the fax machine to more than on your PC, your PC should receive the fax first and accomplish your goal.
Dec 19, 2007 | HP LaserJet 3500n Printer
Winfax pro suddenly faxing to wrong number
you have some options, so choose one.
  1. remove your fax
  2. configure your fax to answer later (maybe after ringing 10 times) and configure the winfax to answer before (something like ringing 5 times or less)
the problem here is that the fax answer and start receiving the fax and the winfax receive the fax signal at same time. check the winfax maybe you have the half part that the fax modem not has printed stored in winfax, maybe.
as I said, your better choice is removing the fax modem. even configuring like I said before, maybe the two continue to try to receive the fax at same time.
hope it helps.
Dec 13, 2007 | Symantec WinFax Pro for PC
Received fax is incomplete
You may have a problem with the print spooling or cache. A fax being a picture takes a lot more memory and is not compress the same way other pictures are. Many printers, especially inkjet aren't really setup with a lot of ram.
I suggest you go to the manufacturers website and look up their customer support, FAQ's and community. You will find you are not the first one with this problem, and there will be suggested resolutions.
Oct 26, 2007 | Symantec WinFax Pro 10.0 for PC
Symantec WinFax Pro for PC Logo
178 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
