Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
32 inch sony trinitron wega
My 5 year old sony trinitron wega will have a difficult time turning on when shut off for more than an hour. It turns on fine when shutdown for a short period of time but if shut down for longer periods it seems to power up ( as in you hear a high voltage noise) but no video or audio and the standby light flashes 7 times. turnig it on and off about 8 times seems to get it to turn on. It has never not come on at all. The model # is KV-32HV600 The serial # is 8017348
  • sfcu Mar 01, 2008
    what capacitors would i need to replace?
  • 1,512 Answers
It will most probably need an overhual of the power supply
Posted on Mar 01, 2008
  • 3 more comments
  • Graeme Ross
    Graeme Ross Mar 01, 2008
    electrolytic capacitors slowly deteriorate with use and replacing them fixes most waning power supply problems. This is not really a job for someone with no high voltage experience, but if you are nimble enough with a soldering iron, I can get you the service manual and you could do this repair yourself. Just comment back here with what you want to do.
    regards
    Graeme
  • Graeme Ross
    For some great "how to" procedures, go here also. It will help with troubleshooting your set.
  • Graeme Ross
    whoops... forgot to paste the link... i meant here ;)
  • Graeme Ross
    1. Turn off the television.
    2. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    3. Unplug the television power cord from the electrical outlet.
    4. Let the television remain without power for 60 seconds.
    5. Plug the power cord back into the electrical outlet.
      NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    6. Turn on the television.
    Here is a procedure for doing a rest on the TV. Try it also to see if it helps.
  • Graeme Ross
    *reset
Sony trinitron, about 7 years old, turn it on and picture won't come on for about an hour
Check for bad connections on voltage regulator ic, or bad voltage reg ic in power supply.
Oct 23, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony Tv turns itself off after 5 seconds...blinks 7 times?
Had the same problem. Unplug from wall for 36 hours and then it works.
Hp Sydney Aus
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron Kv24Fv12
stand by timer light flashes 7 times no pic no sound. how do i
stop timer
Apr 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
145 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
