Question about Haier HRF10 Top Freezer Refrigerator
Haeir HRF10 refrigerator
The fan motor is loud
how do I access motor ?
  • Jawhara May 06, 2008
    Can I get your assistnace I have the same model HRF10,and it's problem start after two year from the purchase date ,The problem as follows:-
    The fan motor gives a noisy for few days and after that the botom side of this refrigetor stop cooling totally ,the technician advised us to change the fan of of this bottom side and he replaced with new one many times (six times),but unfortunately the problem can not solve till date
  • lmk400 Oct 21, 2008
    freezer is cold cold....fridge part is at about 50 degrees
Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
Posted on Jan 08, 2009
Where can i buy a haeir chest type freezer?
Posted on Dec 17, 2008
  • lybelle2575 Dec 17, 2008
    do you have a chest type freezer
The heater/AC makes an obnoxiously loud noise coming from the passenger side around the glove box when turned on. Has been developing for about a week.
Sounds like your blower motor bearing is going bad. Pull glovebox and you can access blower motor. Pull blower motor and check that fan/cage is tight and not clogged with leaves etc... Had an instance when mine made a bunch of noise found parking stub had been sucked into fan,
Jan 03, 2011 | Honda Civic Cars & Trucks
My hood fan is making a loud noise, due to it has gotten moisture after a snow storm. Can i spray WD-40 onto fan to quiet the noise?
Usually the fan begins to make noise when the bearings in the fan motor become clogged with dirt or just wear out. You must get access directly to the fan housing and spray the bearings directly. This may consist of taking off a couple panels.
Dec 22, 2010 | Microwave Ovens
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Loud Noise when freezer door is closed (as if fan is not working)
it is the fan or the blade hitting something when you open the door it shuts the fan off and on when closed you need to gain access to the fan and see if it is the motor of the blade before you lose any food
Jan 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fan motor noise 2005 t bird
do you have a mechanical or a electric fan?
acording to your question seems to be electrical make sure the fan nut is tie and there is no cracks on blades
also wigle the ft shaft up and down and if you feel any play the replace the motor
Jun 01, 2008 | 2005 Ford Thunderbird
Dishwasher noise
open the bottom access panel up , look at the motor in front of you past the motor its self you will see a fan blade if it is loose then you need a new motor pump assy
Apr 30, 2008 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Sub Zero side by side loud noise when the fan/motor is running
sound like you condensor fan motor is going out... it might be a Compressor problem.. .check the condensor fan motor and proper air flow..
Nov 13, 2007 | Sub-Zero 661/F Side by Side Refrigerator
Fan making loud noise like it needs oiled
Most of the fan motors can be oiled. You will have the slide the ac forward and remove it from the case to access it. You will find yellow pull pins on each end of the motor, a lite drop or two is all that is needed.
Aug 16, 2007 | LG Electronic Window Air Conditioner
Noisy fan
We had our house built with the same Nutone fan/light units in all 4 bathrooms. Moved in in 2002. One of the units starting making a loud noise last month. I popped the plasic cover off the light, then carefully pulled out the bulb, then unscrewed the wingnut in the middle. That allowed removal of the light assembly. Then I had access to the blade and motor. I found a lot of dust had collected on the motor and blade. I blew most of it off with compressed air (like what you would use on a computer), then used an electronic cleaner on the motor, then wiped off the blade and motor with a clean cloth.
I then crossed my fingers and turned on the fan.... It worked! It was quiet again. I waited a week before posting this. The fan is used every day. It is still quiet today.
If it ever needs replacing, I saw that Nutone sells the motor alone for about $22, that's a lot better than replacing the whole unit for around $70.
Mr. J.
Nov 17, 2006 | Broan-NuTone N-769RF Combination Light Fan...
Haier HRF10 Top Freezer Refrigerator Logo
601 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
