Need help I have a Quad JR when using my pedals i get no volume or effects in my head.
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hey ss
    what sort of pedals are you using. what style of sound are you looking for and how hard are you crunching yo sound?
  • 1,512 Answers
Happy to help you, just get back to me here :)
Posted on Mar 16, 2008
Suggest a good delay pedal to buy for guitar.
According to many musicians rating, top three best delay pedals are:
? Donner Yellow Fall Vintage Pure Analog Delay Guitar Effect Pedal
? Behringer Vintage Delay VD400
? TC Electronic Flashback Delay and Looper Guitar Delay Effect Pedal
All these delay pedals are best in different conditions, you can choose any of them.
Tho check their reviews, you can visit this link:
Best Volume Pedal Top 5 Best Volume Pedals Reviewed by Musical Study
Feb 22, 2017 | Cameras
Which is the best chorus pedal for a guitar?
According to me and many professional guitarists, the best chorus pedal is "MXR M234 Analog Chorus Guitar Effects Pedal"
It is durable and easy to use.
Some of its best points are:
? Volume is consistent
? Affordable price range
? Versatile tone and effect
You can check many other effects pedal at this link:
Best Chorus Pedal Top 5 Best Chorus Pedals for Your Guitar 2017
Feb 22, 2017 | The Music
Where can I find the best volume pedals?
Currently, the best top 5 volume pedals are:
1. Ernie Ball VP Jr. P06180 250K Potentiometer for Passive Electronics
2. Ernie Ball MVP, Most Valuable Pedal
3. Boss FV-500H Volume Pedal - High Impedance
4. Dunlop DVP3 Volume(X)
5. Mission Engineering VM-PRO Volume Pedal Pro with Buffer
You can check their reviews here:
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
When i'm on clean sound the machine sounds ok, but when i switch to other effects on factory setting the effects sound level cut down tremandously. it just sound like being muted or being **** in. any...
A lot of pedals when on bypass actually just connect the signal straight through... WHILE when using the effect, the volume control parameter is active. You need to balance the effect volume control against the straight through level which you have no control over.
Jan 06, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
Hi i use a peavey 6505 Amp head and when i run a seymour duncan pickup booster through the effects loop it blows the amp (possibly the pre-amp fuses) i want to get a volume boost in a distorted setting...
Hi bmwz43
Odd that you keep blowing the head... and with 5 12axl preamp tubes even more surprised that you cannot get enough gain... :) Get the correct pedal for the 6505 and change yo levels that way. Hard to beat classic tube amp for tone:)
Check the the amp has the correct impedance setting for the quaddy you are using.
One more thing, what sort of cable do you have connecting the amp to the speaker box. If you use a cheapo guitar jumper lead arrangement, expect that to give you trouble AND **** tone. The 6505 has 120watts of cranked up tube output. Tube output stages need a solid at least 18 gauge cable and quality connector jacks, like Switchcraft. They can blow fuses if you don't use a decent speaker connector lead.
Get back to me here if it does it again, and check to see exactly which fuse you are replacing. It can help sort out the problem.
Apr 27, 2008 | Audio Players & Recorders
18 people viewed this question
