Question about Sony MEX-DV2000 CD Player
Disc blocked for your safety
When i put a dvd it work for a five seconds then it stop telling me(disc blocked for your safety)
Have you connected the parking break cable?
Posted on Mar 26, 2008
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
We can't watch DVDs as it says DVD blocked for
your player probaly has something wrong with it and ur tv is telling you not to use, so buy a new dvd playeer
Dec 27, 2012 | Televison & Video
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
Can't turn off progressive scan on my dvd/vcr player.
Page 18 of the operating manual cites this, to reset to default viewing mode:
1) Remove any disc from the unit and close the disc
tray. See that “dISC” is displayed on the display
window.
2) Press STOP and hold it for more then five
seconds before releasing it. The video output will be
restored to the standard setting and a picture will
once again be visible on a conventional analog TV or
monitor.
If that doesn't work, please let me know.
Mar 19, 2009 | Zenith XBV443 DVD Player/VCR
I have a Cyberhome CH-DVD 300 and put it in progressive scan
turn on dvd player,leave disc tray close,press and hold in the stop button for five seconds,the dvd player will restore to factory settings and you will see the welcoming screen again,happy viewing watching your favourite dvds
Feb 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Toshiba laptop a105-s4034
You need to set your CD/DVD/CDRW Disk Drive to Boot First. If the Second set of Recovery CD's don't work, Then they are the Wrong one's for that unit.
Feb 12, 2009 | Toshiba Satellite A105 Notebook
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
Stuck dvd disc.
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
Feb 24, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
XBV442 combo
With no disc in the DVD player, press and hold the stop button on the front of the player for five to ten seconds. This was answered elsewhere. I just tried it and it does not work with the remote, just on the player itself.
Aug 26, 2007 | Zenith XBV442 DVD Player/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Sony MEX-DV2000 CD Player Logo
466 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
