Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
HDTV-AT&T UVERSE I had UVERSE installed yesterday and my picture is better than with charter but I still dont think it's HD quality. I'm using Red, Green, Blue cable. But when I go to select 1080 or 780 the picture becomes scrambled. I tried to switch to input 4 which is the HD input and then I get no picture, however in input 1 (CVI) I get standard drf picture.
    Problem Solver:
  • 11 Answers
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Posted on Feb 14, 2009
I had the same problem. Using the standard definition (cvi) input, navigate to options->screen resolution in u-verse and get to the point where all you need to do is click "ok" to switch to HD resolution. Change the component cables to the HD input and then press ok on the remote to switch u-verse to HD resolution. I can't explain it, but it worked for me.
Posted on May 13, 2009
  • 3 Answers
You used cable box company call and set up that box first and after that set-up you tv.
Posted on Mar 09, 2008
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
Panasonic TC P50S2 tv loses sound fairly often. use at&t uverse hd receiver and after rebooting the dvr/receiver, the muting problem is gone for between 1 day and and 2weeks. at&t says the tv...
Use the component connection not the HDMI. Some of the ATT boxes have issues with the HDMI ports. Uverse is only broadcast in 1080i not p so you will not lose any video quality.
Apr 27, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Picture quality on hdtv
Well it might be working just fine. Personal preference of HD plays a great role in this. Try asking other people if they think it looks HD worthy. If the cords work just fine and are plugged in into the correct A/V jacks, then it could just be your personal preference on what HD is.
Apr 28, 2009 | Sony Playstation 3 (PS3) Console
Hi. im a french guy so you could not understand really what i want to ask.Yesterday i bough a Sanyo HDTV Model No : DP37647 and the image is really ugly ( huge pixels ) compared to my previous old tv. i...
you will get poorer picture quality if you aren't watching on an hd signal . the pixels shouldn't be extremely big, but they will look off compared to a normal tv.
Oct 20, 2008 | Televison & Video
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Poor color
What kind of cables are you using? I had poor picture quality until I upgraded to HDMI, the picture's great now.
Dec 16, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
2,708 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
