Question about Kitchen Ranges
Power Failure in gas range during use
I have a Whirlpool Gold Accubake gas range (Model GS440LEMQ, serial # RR1511795) that is about 3.5 years old. I have been getting a PF code in the middle of baking (it happens at any temperature, not just high heat). It only happens occasionally, but has been happening more frequently as of late. If I don't stand right there, I have no idea when it happens. I can turn the oven on right away again, but depending on the last time I checked on it, I may have to preheat it all over again. It doesn't pop a circuit or anything, it just shuts itself off. I called in a repair guy from our gas company (we have their service plan), and he had never heard of this problem. He didn't even open his toolbox to investigate. He said he would call his parts guy and see if he has heard of anything like this and left within minutes of getting to my house.
What is the problem and how do I get it fixed? Thank you in advance!
  • 1 more comment
  • triq Dec 23, 2008
    same issue with my frigidaire range.
    whenever I turn on the oven...it clicks and the PF light goes on...and no oven.
    Tomorrow is Christmas eve... UGH
  • Anonymous Jan 06, 2009
    Identical Whirlpool oven, identical problem.
  • Anonymous Jan 07, 2009
    I have a whirlpool Gold Accubake System oven that was in the house when we purchased it last year. Looks rather new, but not sure how old it is. It shuts off in the middle of baking, and we have to unplug it, and plug it right back in for it to work again.
    Same issue though, no idea when it shuts off unless we are standing in the kitchen to see it.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Sounds like a power issue for sure, check your outlet that its plug into(run an extension from another outlet to be sure), perhaps a loose wire on control board behind unit. PF is inicator that power failure has occured. check your manual oerhaps a 5 year warr on electronics(might be a short in clock itself)
Posted on Mar 02, 2008
Whirlpool accubake gas stove. Burners work,oven does not, and display is out. Stove is 11 years old.
Grant Schertzer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Grant Schertzer ), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Kitchen Ranges
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Jan 10, 2010 | Whirlpool GY396 Electric Kitchen Range
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Kitchen Ranges Logo
719 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
