Gateway 831 GM won't boot up no signal is showing in the begining
I tried to turn on many times and no signal is showing always
    Guru:
  • 147 Answers
Ram,
It sounds like the problem is either your power supply OR the motherboard. A power supply swap doesn't take long or cost much.
On the other hand, replacing a motherboard takes 30 minutes or longer and can cost upwards of $100!
Please let me know if this helps. Good luck!
Posted on Mar 01, 2008
  • Alexander Kogl Mar 13, 2008
    Ram,
    Has this solution helped? Please let me know!
    -Thanks
I turn on my power on my gateway, I here 1 beep then after that comes 2 beeps, my monitor is showing no signal
ohhhhhh a running Gateway, (nastalgic to the max)
the beeps are gfrom the motherboard.
they have meaning,]'
there is no standard, only the gateway book on your PC
covers it. t
these are called cold boot errors from BIOS ROM.
can be bad memory
or bad video card.
if you have 2 or more memory sticks?try them one at a time in bank 1 slot (lowest)
if that works try a spare video card.
Feb 16, 2017 | Power Computers & Internet
My gateway 4540GZ won't boot up when I turn it on
Disable other bios setup and enable only the hard-disk.The procedure is these:put on your machine for the first time immediately press (F2) button.if it refuse to display off your machine and restart Then immediately press (F9). when it display the setup locate and select boot menu it will display all the booting function such as: CD/DVD RW, HARDDISK,ADAPTER AND SO ON just select each one it will show two options:ENABLE/DISABLE. you just select disable for others except HARDDISK should be ENABLE.finally,close it and apply save& exit.restart your computer it will definitely boot up.
Nov 24, 2011 | Gateway Computers & Internet
I had a fan making a clicking sound & a Friend cleaned it & now it turns on but nothing on the screen, what is messed up? where can I find parts to fix it? This is on my Gateway 831 Gm it has a...
Hi jdr_dlr519!
Pardon me.... but did your friend connected the monitor cable correctly on the system unit? Cleaning the fan will not break your computer... however, if he forgot to disconnect the power cables before opening the unit, it may do a damage.
Jul 20, 2011 | Gateway 831GM PC Desktop
When i turn my computer on my momitor wont come on without my help i have to push the button on side of monitor6 time then it comes on
Are you giving the computer time to begin sending a signal to the monitor. Some computers send a brief low resolution signal during BIOS load, then put the video back into sleep mode while loading the operating system. The video drivers are usually loaded fairly late in the boot/OS load cycle. You may just not be waiting long enough.
Jul 04, 2011 | Gateway (G-MAX2000) Computer Speakers
Desktop will not boot at all. Turn it on and it will begin once and quit. Second attempt it begins to run ( fans ) at what seems half speed. Occasionaly it will start with fans at full speed. It will not...
Sounds like memory to me, if it has more than 1 stick of memory try using just 1 at a time to eliminate the faulty 1. If theres only 1 stick try replacing it. Cheers from Scott and plz vote
Jan 14, 2011 | Gateway GM5420 Refurbished Intel Desktop...
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
Gateway 831 GM
if the power supply was not the issue try memory,cpu and the motherboard..
Apr 22, 2009 | Computers & Internet
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
Gateway GT5228 booting problem
"Also after I try to turn it on after a couple of unsuccessful tries, it actually boots and the machine works fine". This maybe cause by the hardware problem. And it usually caused by the motherboard. Changing the motherboard unit may solve the problem. But make sure you've already done the basic test on all of your hardware before changing it with a new one.
Sep 21, 2008 | Gateway (4000531) Motherboard
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
