Question about HP Pavilion a305w (DM181AR) PC Desktop
Hp a305w will not boot to windows
Turn computer on , and will stay on a blinking cursor , will not allow a fresh install of os. changed out all parts i can think of, hd,ram,cd rom, cant get nowhere. help! have this problem on 2 hp computers, a305w and a 350!
  • 28 Answers
I solved a similar problem I had by pressing the function keys upon booting up. Then, when I found the correct buttons to get into the bios, I was able to set the correct boot-up device(s).
Posted on Mar 01, 2008
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
    Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
    Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
    How do i erase windows 95 and replace it with windows 98?
    you get a copy of windows 98, pop in the disc, click upgrade (or fresh install if you don't wanna keep anything), and let her install. About 45 minutes after it reboots you should check on it because it has a dialog box for you then.
    Sep 27, 2009 | R.A.M. Computers Featron FT6750, Pentium...
    Gatewat 4525GZ Intermittenly cant find DVD/CD Drive
    The fact that the CD ROM works at all means them MOBO is ok..just replace the CD ROM as they are not that expensive any longer and save yourself some headaches..good luck. Let me know if you have have questions.
    Rate with 4 diamonds.
    Mar 07, 2009 | Gateway 4525GZ Notebook
    Dell Precision WorkStation 650 crashed and restore CD won't load
    If possible try changing your cd rom or dvd rom for cd use check it is recognised in bios and change bios to boot from it,if you still get the black screen with flashing cursor ,could be os is missing due to hdd failure
    Jan 09, 2009 | Asrock AM2NF3-VSTA (4711140874470)...
    Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
    Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
    Dec 09, 2008 | Computers & Internet
    When i start pc read ram and blinking not booting or loading o/s
    your os is corrupted if you wanna to load from the cd-rom if have change the boot order option in the bios and make it first cdrom then it will boot from the cdrom and you can repair the windows installation on the hard disk - to go to the bios u have to press F2 or F10 see which key its says while booting to go to the bios
    Sep 27, 2008 | Compaq Evo D500 PC Desktop
    Boot problem
    Did it boot at any time you had it?
    How far does it boot from the hard drive now?
    Are there any messages?
    Are you trying to boot from the usb cd rom with an xp disk?
    If you can do that, personally I would just reinstall windows.
    Hard Disk removal is not a difficult process on a laptop. You can connect it to a pc with one of those external boxes for 2.5"drives, cheaply available. XP will not boot if you put an installed copy on another computer (unless it is exactly the same).
    Worst case (a process I once had to do with a tablet pc) is to make a small bootable partition on that hard drive, put the xp install files on that partition, then put it back in the laptop and install windows from the small partition onto the rest. There are more detailed instructions how to do this, if you go that route.
    If you take parts out of your laptop, make sure you don't give it a static shock by touching something grounded.
    Jul 04, 2008 | Computers & Internet
    HP Pavilion a305w (DM181AR) PC Desktop Logo
    134 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
