Question about Alpine TME-M740BT Car Monitor
Bypassed the small internal speaker and ran it to a door speaker hookup behind the dash, now no sound at all
I opened up my tme-m740bt took out the small speaker, ran speaker wire from the 740 to have it work with my door speaker. worked for a few, started giving me trouble when the stereo was on, whining sound, so i assumed the amp wasnt getting along with the audio coming in, so i took the wire off. tried a few different places, to include a sub. nothing seemed to work, hooked it back up to the small speaker just to make sure it wasnt my speaker wire, and it worked. i was contemplating putting the small speaker back in when it stopped working all together. no sound at all now. cant really call alpine since i took apart the product.
    Problem Solver:
  • 51 Answers
Please check www.playpower.com.cn
Posted on Mar 18, 2008
How do I disconnect the chime from automatic door .Had to cut cable as it jammed . Took out fuse but radio and clock now do not work .Can I disconnect wire from chimes .I knoe it comes from speakers .
try this
disconnect battery
undo the fuse box and look at the wires behind that fuse you pulled
check that only radio and clock wiring are fitted there
the chime may its own power source
i could be wrong
i thought chime was separate to sound system speakers
and comes from a small but loud sound device on the instrument panel circuit board ..much like a computer
May 28, 2014 | 2005 Buick Terraza
Compaq internal speakers
Did by any chance you have been using vlc at more than 100% sound level? If yes then chances are they are toast.
Can you hookup external speakers or headphones and see if they are working?
Oct 29, 2013 | HP Computers & Internet
How do i remove the fron't door panal on a 2004 kia optima lx
To removed the door panel. Remove 1 screw in the grab handle pocket, 1 behind the door open lever, and 2 screws at the forward edge, the bottom edge, and the rear edge. Remove the small window-corner speaker if equipped. Then lift off the door panel. Don't lift too far, there are wires to disconnect.
Door won't open?
For those of you whose door is shut and you cannot open it, here is the trick that the Kia mechanic. Insert the key into the door lock. In one quick motion, simultaneously turn the key to the unlock position AND pull the handle. It took us several attempts to finally get it to work.
Dec 05, 2010 | 2004 Kia Optima
I ISTALL A CAR STERIO ON A 84 MERCURY GRAND MARQUIZE AN I HAVE NO SOUND ALSO I USE AALL INSTALATION KITS AND I TOOK OUT YHE ORIGINAL STERIO
did you bypass the amp thats mostly located in the trunk on the right side behind the cover. Either its there or under the rear speaker deck. You have to bypass that amp before the speakers will work and there is a kit for that too.
Apr 03, 2010 | Car Audio & Video
02 bonneville. Stock radio has power, but i install my pioneer and no power. I did use a wire harness.
With the stock radio installed, turn on your parking lights and listen for the chime (same sound for key in ignition with ignition off and door opened). Does the sound come from the front left speaker or from behind the dash? If it comes from behind the dash, disconnect factory stereo and turn lights on again, id the chime still there or does it go away? If the sound comes from the left front speaker or goes away when you unplug the factory stereo, you need a different harness, its called a chime harness Pac Audio part #C2R-GM32R, could be the thing you need.
Mar 01, 2010 | Car Audio & Video
1998 chrysler concorde lxi rh side view mirror installation. how do I access the plug, which is inside the door panel so I can unplug the old mirror plug and install the new mirror plug. I took off the...
you must remove inside door panel all the screws going into door including screw for inside door handle. you will be able to reach it then. try not to break any brackets surrounding screws(you will have a loose door). took me 15-20 min.
Jan 17, 2010 | 1998 Chrysler Concorde
2002 Yukon XL with Delco Stereo only has front passenger speaker working and the sub. High end sound coming out of driver front speaker, nothing from 2nd row speakers. Is this wiring issues or problems...
sound like the head unit's out put mosfet is going bad, but i have also ran in to this problem when it was a speaker wires shorting out. so first check the connection on your rear speakers.
Oct 15, 2009 | 2002 GMC Yukon XL
Aquos LC-32D43U, no audio
My suggestion would be to bypass all of your video components whatever you have be it a vcr, dvd player,whatever and just hookup the tv direct to whomever you receive your cable tv from. Because it was working before you moved it and disconnected the external audio source. Remember if your using HDMI cables they are your audio and video together and you don't need to hookup anything else from that device to the tv. Just FYI. Good luck.
Jun 19, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Passenger side window
Hi
You need to look behind the internal door handle with which you open the door, the internal door handle with which you pull the door shut, below the door pocket, and if there is one fitted, behind the little "tweeter" speaker by prising off the front.
You may also find some around the edge of the door panel.
Very best regards
Geordie
Dec 15, 2008 | 1999 Volkswagen Golf
I dont get any sound
Many vehicles have factory amplifiers that must be activated or bypassed when installing a replacement head unit. If the factory amplifier isn't integrated or bypassed, you won't hear sound from the factory speaker locations. Another possibility is that you have a shorted or pinched speaker wire or terminal. A short at any speaker will shut down the head unit's internal amp, killing the sound to all the speakers. The RCA outputs wouldn't be affected, so the subwoofer keeps playing.
Feb 23, 2007 | Jensen VM9510 Car DVD Player
Alpine TME-M740BT Car Monitor Logo
176 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
