Question about Frigidaire GLWS1233A Top Load Washer
Leaking frigidaire top load washer
Water appears to be leaking from the top of the tub and leaking inside my Frigidaire FWS445AFS0 top load washer. Happens during wash cycle. All hoses good, pump dry, but water runs down the side of the tub.  Is there a seal at the top? Could it be cracked? A lot of water.
  • 2 more comments
  • airgate Jun 14, 2008
    I have water leak over tub during spin cycle GE model WWA8330G
  • Anonymous Mar 25, 2014
    leaks I believe after wash cycle
  • Anonymous Mar 27, 2014
    frigidaire top loading washer.
  • Anonymous Mar 29, 2014
    Large loads water leaks out side hose
  • 156 Answers
Yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
I have a frigidaire affinity front load washer and it's leaking out the back at the top right corner. Do you know what could be causing this?
Hi ajdean01 - I see that your tub appears to be leaking. Here are a few troubleshooting tips that may help you get to the root cause:
· First, be sure that your tub is not overloaded. Sometimes when overfilled, water can and will slosh outside of the unit.
· If the tub is not overfilled, check your hoses and other connections. Like most laundry units, there is always some vibration associated with the functionality of the machine. As the appliance is used over time, hoses and other connections can loosen and begin to leak. Be sure to secure any loose connections.
· If the above items did not assist you in resolving the issue, it could be a number of other underlying causes - primarily an electronic pressure sensor, switch, thermistor or the unit's main control board. These parts are commonly replaced by experienced service technicians.
Apr 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
It leaks water after its about half full does it have a hole in the tub?
I doubt if the tub has a hole in it, BUT the increased pressure and weight of the half filled tub could force water past a damaged washer. How did the washer get damaged, probably by the spin bearing starting to fail.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FEX831CS0/1428/0152000/R0310016/00005?blt=06&prst=&shdMod=
Items 21 and 26 are the parts that I would suspect.
Jul 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
Water leaking from the buttom
your washer is off balence its causing your tub from inside your washer to splash out on spin cycle adjust legs get a level then put on top[ washer see if its balanced then try a load.
Jan 26, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
Frigidaire Front Loading Washer Leaking
there should be a rubber pipe going to the soap draw to the drum normally there's to pips one at the front of the machine and one on the top it is there have a good look in the machine make sure its un plugged be for putting your hands in the machine ok
Nov 28, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
682 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
