Question about Systemax (988970) PC Desktop
No sound i get error code 10!!!!! I cant get my drivers booted. I bought this used ,but now i get this thing from mico soft too
    Sergeant:
  • 349 Answers
Obtain latest sound driver for your sound card or machine, go into device manager remove sound device driver,reboot,when it says found new device ,sellect have disk ,then sellect where you have saved the new driver,then follow the onscreen directions
this should get your sound working ,if it is a hardware problem install a new sound card,(if the sound is onboard ie (part of the motherboard), be sure to disable it before you try to install the new sound card)
good luck
Terry
Posted on Mar 02, 2008
  • terry Mar 02, 2008
    if you are unable to boot up normally ,press f8 when booting up and select safe mode when you get the menu,then follow my previous solution
    good luck
    Terry
A Dell Inspiron 15 3000 series drivers
that error code normally means the dyd or usb ur installing has corrupted files, normally a very large one. make another boot disk/installer dvd
Mar 13, 2015 | Dell Computers & Internet
Dvd error code 10
Cause of the Code 10 Error A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
The safest thing to do is to perform system restore or
run SYSTEM RECOVERY.
If you will use sysem recovery it fix all the problem of your computer however all files on your hardrive and softwares that you installed will gone.
It will be back from original manufacturer settings just like the same thing you got your computer.
Dec 30, 2011 | Sony VAIO S360 Notebook
On my Dell Inspiron 1521: Broadcom Network Adapter Error Code 10
Go to Dell and download the driver from there. The MS driver doesn't actually control the device, only controls function after device is active and working. Look on the bottom or back of the computer for the Dell service tag number, and use this to identify the correct device and get the device drivers. You may also find some other things there that weren't installed by the OS.
Jul 28, 2009 | Broadcom BCM5721 NetXtreme Ethernet...
I have the sound divice but i cant play any thing and i dont here
possible sound device failed, or drivers not the right ones, my newer note book had failed sound device (code 10 cannot start) it started doing static when listening. the failed all the way. i now use an external sound device myself that was about 15 dollars now i have sound again without large cost. this may be an option for you.
Nov 18, 2008 | Digidesign Mbox External Sound System
T6534 boot issue.
Without testing for myself, It sounds like a hardware compatibility issue. Cant say for sure without more info. Try all the components, one at a time, in another PC if you have the capability. Mainly the HDD, CPU , and memory. I have had this happen in the past. For no reason at all the components wont work together. Put them with other components in another PC and they work fine. Cant explain it, but it happens. Not as much as it used too though. Dont expect it would have anything to do with vista, except bad hardware trying to load the OS. If it were Vista, it would at least boot, in some form, even if it went to BSOD. The OS would not corrupt the BIOS. But a bad flash would, (or even a Virus). If you can, Try flashing the bios to the origional version. With the varied problems your having, I'd start there.
Aug 24, 2008 | E-Machines eMachines Desktop PC
Internal wireless card sudden error code 10
M200? Is this a Toshiba laptop? Error Code 10 can mean many things, but the first thing I would try is a Driver Upgrade. Reliable Drivers can usually be found at the manufacturer's website.
Dec 23, 2007 | Computers & Internet
Code 10 error
I've come across this before in some laptops, the manufacturers stupidly, dissable the wireless card in the bios as default, so if you know how to get in there, it needs to be enabled. Only other thing a code 10 means is the hardware is faulty, but if it was ok before, should be ok now.
Oct 29, 2006 | Fujitsu LifeBook C1110 Notebook
Systemax (988970) PC Desktop Logo
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
