Question about Canon PIXMA iP1600 Printer
Size of printing
When I print a screen from a company(say ATT) or a receipe from Kraft co.
and I want to keep that copy, the printing is so
small, one needs a magnifing glass to see the print. Is it possible to enlarge it? I have tried everything.
All other printings are about normal.
Please advise..............
Thank you
Teresa G.
  • howdy2 Mar 02, 2008
    I tried your suggestion, it will be fine for other problems. Then I realized it is comming from my source, it is not from my printer. They must enlarge their printing for it to be ledgeable.
    Thank you.
  • 28 Answers
I have had the same problem before, and the way I solved it (if its the same problem as you) is I went into the "view" menu and under text size, select Medium or Larger.
Posted on Mar 01, 2008
Ehow co uk
If you use the print command from the menu, the page should print out as it is.
You could try a screen dump and copy the page as a document and re size it.
May 27, 2014 | Computers & Internet
The printing is too small
there should be a icon for expanding the original under the copy, number of copies screen. That will work for copying a document. If printing a document from a PC, use software such as WORD is increase the size of an image or text.
Apr 29, 2011 | HP Office Equipment & Supplies
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
How to change print size
The printer prints whatever it's told to by the computer. Your printer really doesn't control the fonts.
When you are printing stuff from the internet (web pages, email, etc.) the reason for the small print is that it is related to the size of the monitor and it's viewing setup (the higher the screen resolution, the smaller the print will be when printing it out even though it looks good on the monitor).
One way you can make the print larger when printing internet stuff & emails is by changing the print view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Another method is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow for a drop down list and choose something probably above 90% or more (maybe 100 or 125%) and see how it changes the print size of what is to be printed out.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
Nov 05, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to enlarge print
before you print, select all the text and resize it to a higher number (say from 12 point to 14 point) then print, (but dont save). that may help. The problem is, your resolution is larger than the actual size of the item, so you are getting a 'magnified' look at the screen. So anything normal on screen will be smaller when printed.
Jun 30, 2010 | Dell All-in-One Printer 810 with 2-Year...
Refurb 4345 envelope double prints
Measure the distance between them and let me knw what it is. Make sure to measure from the same point to the next same point. For example name on letter is "Att: Mr Ed" you will measure from the left bottom of the "A" on "Att:" to the left bottom of the next instance of "Att:"
Nov 15, 2009 | HP LaserJet 4345mfp All-In-One Printer
Printed font size too small
Most web browsers have an option to change the text size on the page you are viewing. In IE8 it is accessible through the Page menu, Text Size. It defaults to Medium, and there are 2 smaller sizes and 2 larger sizes available.
May 29, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Want to print 3 different 5x7 cards at one time
Set the layout in the screen (according with the layout of the paper / cards you are going to use) --> set the 3 different texts (receipes) in the screen according with this layout--> print
Nov 02, 2008 | Broderbund PrintMaster Gold Version 18
Print too small
There is a copy setting within HP solution center where you can change the copy size. Set it to "Actual Size" or increase the percentage to get bigger prints.
Jun 07, 2008 | HP PSC 1410 All-In-One InkJet Printer
Canon PIXMA iP1600 Printer Logo
old marine
old marine
