Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor Went Black
The monitor had a few blinks of a thin, horizontal line, then it would blink off and blink on. After a few times, it finally wouldn't come back on at all. We did get a blue screen that said something about checking drivers, super drives..., but it didn't come back on before I could write everything down.
Help.
Also the letter codes in the back on the computer say everything is operating fine. Could it just be the monitor went out?
Another strange thing, when I unplug the monitor from back of the computer the power light on the monitor goes green and appears to work by showing a color spectrum box.
Thank you in advance.
Tamlyn
  • 28 Answers
It sounds like the monitor might be going bad. I would try hooking up another computer to it. If it works with another computer, then I would say the Video card might be going bad.
Posted on Mar 01, 2008
I have a Panasonic TC-P50G10 television that now has numerous small horizontal black lines. Can you advise?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 11, 2016 | Panasonic TC-P50G10 Plasma TV
Thin horizontal black line on lcd monitor
It sounds like the light has gone out at that point on the screen, you're going to have to replace the LCD monitor itself.
Feb 23, 2013 | Motorola Mobility XT530 Fire XT Black...
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
My Dell E2209WC have black horizontal bands/lines all over the screen.
if the lines are like blinking and appearing and vanishing, then try adjusting the cable attached to your monitor or buy a new cable that is attached between monitor and system unit.
Feb 22, 2011 | Dell 2209WA 22 inch Monitor
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Horisontal lines
make sure the cords are connected properly from both the computers end and the monitor
Feb 03, 2008 | BenQ FP931 (Silver, Black) (Black, Silver)...
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Jan 04, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
Alun Cox
