Question about Castelle LANpress Jr. MP (66298601-040) Print Server
Summagraphics t1300 cutting problem
When i try to plot an image the machine starts but the actuall cuting head comes down as if to start plotting then it goes back up the head moves left to right no problems and the media moves back and forward and the knife rotates but doesn't come down and make contact with the media i've tried to increase the knife pressure and tested the coil and it goes down not a problem until i try to cut a job
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
After press graph key I get "err invalid dim"
The calculator thinks you're trying to graph a function that involves stat plot features when the function actually does not. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Jan 23, 2011 | Texas Instruments TI-83 Plus Calculator
I am trying to do a box plot with a TI-84 Plus Silver Edition. I've entered my data values into L1, turned on Plot 1, chosen the box plot, and made sure X1 was set to L1. I keep getting ERR: INVALID DIM....
Hey. I had the exact same problem as you and all I could do was reset the settings to the default settings on the calculator. All you have to do is turn the calculator on, his 2nd (it should say mem right above it). Then click reset then RAM.
Sep 24, 2010 | Texas Instruments TI-84 Plus Silver...
Whenever i try the graph on my TI-83 Plus the ERR:INVALID DIM 1:QUIT comes up and ive checked the STAT PLOT and i have Plot 1 set as ON.
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Sep 09, 2010 | Texas Instruments TI-83 Plus Calculator
Cutter Problem
You need to lubricate the shaft that the carrage runs on. If you dont have the correct lubricant, use sewing machine oil. Switch the machine off and using a cleaning fluid such as methelated spirits or benzine, carefully clean the shaft. Take care not to damage the encoder strip (plastic strip running just above the shaft, its also sharp, dont cut yourself) Also clean the outside of the bushes on either side of the head unit. Then with your hand move the head unit to the middle of the machine and put ONE drop of oil on either side of the head making sure you dont mess any and also making sure it goes to the back and front of the shaft. Move the head slowly left and right, spreading the oil outwards. If necessary use a second drop but do not over oil the shaft under any circumstances, the more oil the more dust builds up. This will solve your problem.
Jan 22, 2009 | HP DesignJet 450c InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
INVALID DIM
on a calc that's work properly, in the 'y=' screen, none of the 'Plot#' things are highlighted. try pressing 'y=', and if you have a 'Plot#" in a black box, go up to it and press enter to un-highlight it.
either it will work as soon as you press 'graph',or you have another problem
Jan 19, 2007 | Texas Instruments TI-84 Plus Calculator
Castelle LANpress Jr. MP (66298601-040) Print Server Logo
180 people viewed this question
Top Castelle Computers & Internet Experts
David Payne
David Payne
Are you a Castelle Computer and Internet Expert? Answer questions, earn points and help others
